FS 20" I-forged wheels
2004 Ran SRT-10,2007 S550,2016 E400c
Bought these off a fourm member here about 7month ago and now its time for something diffrent. 20X8.5 20x10 i-forged daytons with falken 452 245/30 and 285/25. They are made for 211 body 03-09 e class. My car was lowered 2" and no rubbing. They are 2.5 years old total i bought from original owner and have factory boxes if you want. I only put about 3k on rims and tires front tires have about 80% tread left and rears have 100% 0miles on rear got a nail so put 2 new rears on . Ok so here is the deal one of the rears has a slow air leak in the rim i had the set checked when i got the new tires and all the rims are true no bends at all.. The rim shop said there might be a tiny crack in the barrel or a porous spot it can be fix very easy. I also contacted i-forged direct and was quoted 300 to replace the complete barrel. I have 3 sets of wheels right now so im looking to just
cut my losses. Im asking 2000 + shipping for a set of 20" iforged with new tires is a deal.. the pictures are of before i mounted tires i can post more on request . I can be reached here and my email davetulip24@yahoo.com
220 run a high offset say 43et-44 so theywill stick out a tiny bit. The offset of the wheels are fronts 32mm 35mm et roughly. I forged dosent give out offsets but i measured the offsets myself, I have test fit them on a cls and sl and with a 5-7mm spacer it was fine.
The picture i put up is from 2 months ago when i got new tires so conditon is above average. always taken care of by the preivious owner and me... ill take pics tonight
As you can see even for 2.5 year old wheels they are in pristine condition.. The lips were polished last january and they were removed from the car and fully cleaned every 2weeks or so.
After so reserach and a test fit.. they will fit a 220 body. Offsets on after market 220 20" wheels are in between 32 -38 on a 20x8.5 wheel and 36-40 on a 20x10 so. these wheels do fall in to range . There are on the edge of the range so they will be flush with the wheel wells but will clear.
