FS/FT: EXE Konakave wheels 19x9.5 +25 5x112 So Cal
Fitment for CLS, CL, SL.
Bolt Pattern: 5x112
Offset +25
C.B: 66.59
Price: $750 or trade for staggered set of 18" AMG
https://mbworld.org/forums/wheels-ti...an-1350-a.html Let me know?!
Compared to a 19x8.5 +30 wheel, 19x9.5 should fit fine all around. The backspace will be 7mm deeper and should be flush with the fender. Recommended tire size would be 245/35/19 all around so you can rotate your tires.
19x8.5 +30 has a 5.9" backspace.
19x9.5 +25 has a 6.2" backspace.
The 19x9.5 wheel will be 17mm wider and 7mm deeper (.3"). It will stick out only 5mm more than a 19x8.5 +30 wheel. Basically the tire will be 5mm closer to the fender so i guess rolled front fenders are recommended if lowered.
I don't understand the what the fun part is? maybe me teaching you about fitment is fun to you
. It all depends on the tires, since some tires stretch more than others. 245/35/19 is fine and not that much of a stretch on a 9.5 rim. I'm talking from experience, not some miata garage calculator.
This is what a 245/40/19 looks like on a m35x with 9.5 rims all around. This is dangerous in your opinion? ok, buddy.
