F/S H&R 20MM WHEEL SPACER 5X112
Subscribe
Jun 12, 2010 | 12:40 PM
1. vizionclk430
2. virginia beach va
3. pm me for more info
4. part#/bolt pattern/center bore/thread type/width
40556653 / 5X112/66.5/12X1.5/20MM
DRA series spacers bolt to the hub with special wheel bolts (included) and provide new threaded holes for wheel bolts
Each package come with 2 spacers, the following application are known to be fitted with this spacer, other application may also fit, for more info, please visit www.hrsprings.com
71-89 MERCEDES BENZ R107 SL
90-96 MERCEDES BENZ R129 300SL 500SL
97-03 MERCEDES BENZ R170 SLK
76-85 MERCEDES BENZ W123 300 SERIES
87-95 MERCEDES BENZ W124 300E 300CE 400E E320 E420 500E
84-93 MERCEDES BENZ W201 190E
04-08 MERCEDES BENZ R171 SLK280 SLK350 SLK55 REAR
94-00 MERCEDES BENZ W202 C220 C230 C280 C36 C43
02-07 MERCEDES BENZ W203 C230 C240 C320 C32 C55 REAR
97-02 MERCEDES BENZ W208 CLK320 CLK430 CLK36 CLK43
03-06 MERCEDES BENZ W209 CLK320 CLK350 CLK500 CLK550 CLK55 REAR
96-02 MERCEDES BENZ W210 E320 E420 E430 E55
5. $100 shipped used them for like 10 miles but there to aggressive for my wheel and tire combo. Practically new spacer and bolts just have mounting marks.
6.
Jun 12, 2010 | 07:51 PM
I want these for my 2009 CLK550 rear.
will these work?
6.
Jun 13, 2010 | 01:01 AM
I don't know use the part # and look on the H&R website to see if it will work I had them on my rears
Jun 13, 2010 | 07:18 PM
I'm very interested!!
you take Paypal?
Jun 14, 2010 | 07:06 PM
sold on its way to badblack550
Jun 17, 2010 | 01:10 PM
the bolts you suppled are a little too long and they scratch against something inside.
I had to remove the spacer immediately .
Jun 18, 2010 | 07:42 PM
Quote: the bolts you suppled are a little too long and they scratch against something inside.
I had the same problem, bought the wrong bolts. I give them to a friend working in a machine shop and have them shaved down, no problem.
Jun 20, 2010 | 04:20 PM
The bolts that are in the box is what came with the DRA kit. As dark night said shave them down a little. they work with my application. Hope that helps.
Explore
Subscribe
Currently Active Users (1)
