FS: Hammer 17x8
Subscribe
Nov 9, 2010 | 09:44 AM
i got a set of mercedes wheels with tires for sale. i own a VW and i was running these for a while until i got new wheels.
specs:
17x8
et35
5x112
tires 205/45/17
3 have about 50% tread on them
1 i had to trade out bc it was blown so its got about 30% tread left
they need to be balanced
all have minor rash but cant be seen when plasti-dipped
they are plasti dipped
shipped:$400 (OBO)+what ever it costs to ship 4 wheels with tires (OBO)
picked up:$400 (OBO)
good set to use as winter wheels
only pics for now...more upon request
heres the wheels before they were washed and plasti-dipped and the 4th tire was added
Nov 9, 2010 | 12:43 PM
Location?
Nov 9, 2010 | 01:21 PM
Quote: Location?
opps...forgot that in my profile..
im in NY on long island
Nov 9, 2010 | 05:15 PM
bump
Nov 10, 2010 | 08:48 AM
morning bump
Nov 10, 2010 | 01:52 PM
need these gone...make an offer
Nov 11, 2010 | 10:00 PM
bump upp
Nov 15, 2010 | 09:06 AM
any offer will be considered
Explore
Nov 22, 2010 | 09:44 AM
bump
Nov 22, 2010 | 10:17 AM
what is plasti-dipped......if I may ask???
Nov 22, 2010 | 11:34 AM
Quote: what is plasti-dipped......if I may ask???
Plasti Dip is a multi-purpose air dry, synthetic rubber coating that can be easily applied by spraying, brushing or dipping. Plasti Dip protective coating products resist moisture, acids, abrasion, corrosion, skidding/slipping, and provides a comfortable, controlled grip. It is now very famous amoungst auto enthusaists because you can coat something such as an emblem and if you don't like it, it is much easier to remove than paint, sometimes as easy as just peeling it off. It is quite durable so you can actually wash your car/wheels with it on and it will hold up quite well.
Nov 22, 2010 | 01:45 PM
Quote: Plasti Dip is a multi-purpose air dry, synthetic rubber coating that can be easily applied by spraying, brushing or dipping. Plasti Dip protective coating products resist moisture, acids, abrasion, corrosion, skidding/slipping, and provides a comfortable, controlled grip. It is now very famous amoungst auto enthusaists because you can coat something such as an emblem and if you don't like it, it is much easier to remove than paint, sometimes as easy as just peeling it off. It is quite durable so you can actually wash your car/wheels with it on and it will hold up quite well.
thank you...all of the above is true...and it can be peeled off if you do not like it...or if theres a tough spot that wont come off...a little bit of gas on a rag does the trick in seconds
BUMP
Subscribe
Currently Active Users (1)
