Sponsored by: MB Part Haus
FS: O.Z. Racing Mito II Modular wheels 18x8.5 and 18x10 with Pirelli Pzero Rosso
Old Jun 6, 2011 | 09:54 PM
Ungarisch's Avatar
Tectitgrau S210
I know I'm gonna regret this, epsecially for the price I'm asking :banghead: but its time to go big (20's) on the benzo.
Specs are:
Front: 18x8.5 et20 with 225/40/18 Pirelli PZero Rosso
Rear: 18x10 et19 with 255/35/18 Pirelli PZero Rosso
Wheels are in overall "good" condition, especially for being nearly 18 years old! (made in 1994) All rims have some clearcoat pealing on the lips and the front stars have some paint fade on the side of the spoke. The tires have around 40-60% tread left, and they are quality not cheap chinese Faklens. (around $1k for a set)
Asking $1400 firm or $1600 O.B.O. add $200 for for shipping, pick up in LA is free.
for fastest response email me at ian.derzsi(at)gmail(dot)com
pics:
Old Jun 7, 2011 | 01:24 AM
TruTaing's Avatar
Moderator Alumni
w203 m112
wow! These are some dead sexy wheels!
Old Jun 7, 2011 | 09:12 PM
Outkasted24's Avatar
Correction, Drove An '05 C230 Kompressor SS
Heck Yeah They are!!!
Old Jun 8, 2011 | 10:30 PM
Meeyatch1's Avatar
'94 NSX,'99 NSX Z,'12 C63 Black Series (Prior: '07 E63, '08 CLK63 Black Series,'14 E63-S & 16 C63-S)
Will they fit a W211 E63?
Old Jun 8, 2011 | 10:36 PM
Ungarisch's Avatar
Tectitgrau S210
I dont see why not, there 5x112 and the center bore is 66.56 which is all mercedes, front should clear your brakes as the front star is high dish, rear is low disk and may require a 5mm spacer if you got huge calipers out back too.
If your local your welcome to come and testfit...
Old Jun 9, 2011 | 08:27 AM
threeMBs's Avatar
Only MBs - the best or nothing
These wheels have very low offsets.
There are only four (4) Mercedes models these will properly fit (without protruding past fenders edge):
all 1990-2002 SL (R129)
all 2003-2011 SL (R230) except AMG63 & 65
all CLS (C219) except AMG63
500E (W124).
On a W211 E63, rear wheels will stick out passed fenders by about 1".
Old Jun 9, 2011 | 02:24 PM
Ungarisch's Avatar
Tectitgrau S210
I don't see why a W211 would have higher offset prerequisites then a W210, especially an AMG. As you can see from the photos above the tire does not protrude out past my W210's fender at all. I don't have 295's on the 10's, either way, thanks for your opinion.
Anyways, I guarantee these will fit on a W210 without any rubbing issues at all, can't guarantee other models till I test fit.
Old Jun 9, 2011 | 02:30 PM
Ungarisch's Avatar
Tectitgrau S210
heres a better picture to give you an idea, as you can see theres still room for a 10mm spacer up front and the rear you can still fit a pinky between the tire and fender.
Old Jun 9, 2011 | 04:36 PM
threeMBs's Avatar
The question was: will they fit W211 E63. You're running 255/35-18 at the rear of W210 on a 10" wide wheel so that it would "fit" - the correct size would be 275/35-18 - but that would stick out, for E63 correct size would be 275/35-18 or even 285/35-18 to handle all the tourque - hence it will stick out by an inch.
As far as why it wouldn't fit R230 SL63 and SL65 - those cars come from factory with 19" wheels due to huge calippers and rotors, 18" wheels most likely will not fit regardless of offset.
All above is not just my opinion - when OZ were still headquartered in Miami, I dealt with them directly. I had and still have a lot of OZ wheels, including these Mitos and Operas II with same offsets - they do fit SLs and W124 E500, but not W211. Period.
Old Jun 9, 2011 | 05:46 PM
YNVDIZW124's Avatar
lots of cars
^^^ this is why I don't come on MBworld anymore. Wheel experts crapping on peoples for sale threads ...
This is a w211 on low offset CLS wheels with 255/front 285 rear. I'm sure 275/30 on a 18x10 wheel wouldn't be a problem.
Old Jun 9, 2011 | 07:06 PM
threeMBs's Avatar
Well, then I suggest you stay out as the question was if they fit E63, the reply was yes, but OP does not know that its incorrect, hence this back and force nonsence.
BTW, oem CLS wheels are 9.5" wide et25, not 10" wide et25 as was stated earlier.
Also, these are 10" wide et19 so they do extend extra 12mm or 1/2" (extra 6mm for lower offset plus additional 6mm for wider wheels) over your 9.5" wide et25 wheels, add proper tire width for E63 - that's an extra inch over. Here, plug the numbers: http://1010tires.com/WheelOffsetCalculator.asp
What I'm saying is that we actually tried fitting OZ Opera II 18x10 et19 (identical specs as these OZ Mitos) with 285/35-18 tires on several W211 cars - combination was about an inch passed fender, owners declined fitment. In fact, even on your car, regardless of posted pictures, wheels (9.5" wide with et25) and tires (285) as you specified should have yelded fitment passed fenders on stock otherwise unaltered car.
Per OZ specs these are to fit only cars I posted above. Here, have fun:http://www.wheelmachine2000.de/cgi-l...=alle&param=rd
Old Jun 9, 2011 | 07:16 PM
YNVDIZW124's Avatar
lots of cars
The op didn't ask for an opinion from you either. Per forum rules this discussion should stay out of his for sale thread....
Old Jun 9, 2011 | 07:34 PM
Ungarisch's Avatar
Tectitgrau S210
ok Mr. OZ, you of all people then should know that rim width is completely irrelevant in relation to how far the tire sits from the fender, everything is completely dependent on offset. Meaning a 285 tire will sit at the exact same distance from the fender on an 9.5" rim as on an 10" rim as long as the offset is the same. Since the CLS wheel has a 6mm deeper offset a 285 tire would sit exactly 6mm further out when mounted on my 10" wheel. 6mm equals less then a 1/4". I don't know where your getting this 1" from.
The person with the E63 asked if the wheels would fit his car, not if the wheels would fit his car with a different tire. AGAIN, I'm selling the wheels with the above mentioned tires, not a 265, not a 275, and definatly not with a 285 If hes looking for that ultimate performance wheel/tire package that will get him down the dragstrip the fastest, then these are probably not for him as with all multi piece wheels, there heavy.
so please GTFO of my thread, as I did not ask for your FLAWED OPINION
Old Jun 10, 2011 | 12:37 PM
Sisco89's Avatar
1999 w210 wagon
ohhh. these would look nice on my e320 wago.
free bump
Old Jun 14, 2011 | 08:41 PM
Ungarisch's Avatar
Tectitgrau S210
thanks
Old Jun 14, 2011 | 08:46 PM
Meeyatch1's Avatar
Wow....I did not mean to light a fire. They are one of my favorite wheels ever, and would have liked to put them on my E63....but evidently that is just not something that can happen (properly) with these.
On the plus side, I hope someone buys these! They are BEAUTIFUL wheels, and very classy. Good luck to the seller!
Old Jun 14, 2011 | 08:49 PM
Ungarisch's Avatar
Tectitgrau S210
I hear ya, with a car such as that function > form for sure..
Old Jun 19, 2011 | 10:31 PM
Ungarisch's Avatar
Tectitgrau S210
still available
Old Jun 21, 2011 | 08:38 PM
Ungarisch's Avatar
Tectitgrau S210
price drop by $50 to compensate whatever tire wear has occured since posting of this thread
New price, $1350!
Old Jun 22, 2011 | 12:44 AM
eurotdi's Avatar
2002 CLK55, 2004 SL500
these are some sexy wheels dude, looks nice on your ride....
Old Jun 27, 2011 | 09:15 PM
Ungarisch's Avatar
Tectitgrau S210
koszi teso!
bump thread
Old Jul 7, 2011 | 11:06 PM
awacsdavid's Avatar
CLS500 & C230 Kompressor
PM sent
