Mark this thread as Sold
Mandrus wheels for W211 and W215
2013 Audi S4 Stasis, 2013 Audi TTS, 1996 C3500 Dually, 1967 442, 2005 CL65-Sold, 2006 E320 CDI-Sold
Asking $1100 for a full set (4) Mandrus Wilhelm wheels with Nexen N3000 tires for sale. These are off of a Mercedes CL65 I just purchased. The will fit W215 (CL500, CL550, CL600, CL55, CL63) and possibly W216 cars.
According to the TireRack website they are the correct offset for 211 and W212 (E320, E350, E500, E550, E55, E63
Note the back spacing listed below , these may fit the following cars. If you are interested we can try.
W220 (S280, S320, S420, S350, S430, S500, S600, S320 CDI, S55, S63, S65)
W221(S400 Hybrid, S550, S600, S63 AMG and S65 AMG)
W219 (CLS500, CLS550, CLS55, CLS63)
Fronts are 20 x 8.5 with a 32mm offset and 245/35ZR20 tires. Tires are almost like new and about 9/32 tread.
Rears are 20 x 10 with 275/30ZR20 with a 42mm offset and . Tires are at 7/32 tread.
New the tires are at 10/32 tread depth.
They are in great shape with the exception of a small rub on one of the rears (you can see it in the first picture).
They may fit other models with a 5x112 bolt pattern (Audi A6 or A8 and VW Etc.), but that's for you to determine.
Mounted and balanced this set lists for over $2700, Asking $1100 OBO. More pictures available if needed.
![](https://post.craigslist.org/imagepreview/m/5N45Kf5Fb3k03Mb3H7c4737b10d3f4ccf14d0.jpg)
![](https://post.craigslist.org/imagepreview/m/5L75Nd5Kc3Kb3Md3Icc47dd51fa854a7817ad.jpg)
![](https://post.craigslist.org/imagepreview/m/5F25Jf5Mf3Kf3J43Ndc470ca4afe41ca91449.jpg)
![](https://post.craigslist.org/imagepreview/m/5I15G55Kb3J13N53H2c4755e9bad3e2771516.jpg)
any chance you could measure overall diameter of the wheels? Thinking about them for my 4matic but the diameter front to rear needs to be identical or very close...
I measured the circumference and calculated the actual diameter. The fronts are 27" and the rears are 26.6". If that is not close enough the other option you have is to step up to a 285/30ZR20 tires for the rear and you'd still be money way ahead. According to Nexen they are identical in diameter to the fronts (both 26.8)
http://www.nexentireusa.com/cms_file...pec_Sheet1.pdf
If that doesn't work I could always turn off the ESP and mount the taller ones on the rear of my CL65 and do a couple good burn outs
Are you sure they have the correct offset for 215 series Amgs?
2004 chev 3500 HD diesel, 2004 E55,
