PRICE CHANGE $1000 PLUS SHIPPING~!
For Sale is a NEW set of Euro26 19x8.5-9.5 in gunmetal with chrome lip, exactly the same as the picture.
The boxes are open but never been mounted or used, only to look at. EXCELLENT NEW CONDITION, the blue manufacturing lip tape is still on the chrome lips. Buyer pays for shipping.
19x8.5-9.5 ET/Offset F42 R48
Will fit for certain w204 C-Class and possible new E-Class but not certain.
How do I go about checking fit for a 2011 E550 2 door?
Hi, I thought I replied to this, but I guess it did no go through. You can check the right offset for your car on TireRack.... or visit your local tire shop and inquire. I think these offsets will work with yours but I would double check. Do you know what your original offsets are?
Honestly, no idea. I bought the car a week ago today. Let me try it figure it out today.
When i had my 19 on my C55, the offset is 35 and it fits perfect. Would this work on my C55?
C55TOM, to get an exact 35mm offset with these you would need to add a 7mm spacer on the fronts and a 13mm spacer on the rears.
The offset on these wheels is pretty close to what I have on my 19x8.5/9.5 setup (F44, R46) so I'd guess these could also fit an S55. HTH.
ExploreWhat he said. Yes technically it would work with the correct spacers, I suggest getting hubcentric spacers.
Originally Posted by 123Pokey321
C55TOM, to get an exact 35mm offset with these you would need to add a 7mm spacer on the fronts and a 13mm spacer on the rears.The offset on these wheels is pretty close to what I have on my 19x8.5/9.5 setup (F44, R46) so I'd guess these could also fit an S55. HTH.
Getting ready to order a new set if you do not want to do the deal.
going to storage today, but it will be later this evening. I haven't given you an a definite answer because I want to be sure about the condition, since I have it at the storage and not in my physical hands. I am almost 100% percent sure its in the condition I told you, but a number of things could go wrong, water damage, pest, things shifted.... I don't want to give you a "Yes" then tell you "No" when "IF" the item is not in the condition I originally stated.
But I understand if you want to buy now, please go ahead, I just can't get to the wheels till later on in the evening. Thanks for the patience.
$800 + Shipping
SOLD MY C300 so no longer need these as backup. These are new and never used. The boxes were opened to check for quality and that is it. It has never been mounted.
GL, if that offset would have worked they would have been mine! ugh!!!
Currently Active Users (1)
