FS: Niche Essen w/ tires and TPMS (w211 w212 w218)
2014 CLS 63 S AMG / 2004 E55 AMG
I’m selling a set of very clean Niche Essens with Tires & TPMS -
Wheels: Gray paint w/ machined face (front) 19x8.5 35 / (rear) 19x10 40
Tires: Continental Extreme Contact DWS 06 (front) 255/35/19 / (rear) 285/30/19
Tires are in excellent condition with perfectly even wear and at least 6/32” tread left (50%).
3 out of the 4 wheels are in perfect condition, 10/10 as far as used wheels go.
One of the front wheels has a ~2 inch rash (from the dealer) which looks worse in the pictures than it is. It’s unnoticeable from just a few feet away. That same wheel also has a small amount of deflection that was measured last time I had them balanced about a month ago (see spec sheet in pictures). The wheel balanced fine and there is no vibration from it that I can tell. It’s ~$229 to replace the wheel, or ~$150 to re-round it if it turns out to be a problem for a buyer.
These wheels are great because they are one of the few wheels that come in 5x112 19X10 in good offsets and they are comparatively cheap (in case one needs to be replaced).
This package new (wheels, tires, TPMS) is more than $2200.
Asking $1150.00 shipped OBO in us (Hawaii and Alaska extra).
2020 GLS450 / 2018 E400 Coupe / 2021 Taycan 4s
RE: Wheels
May I get the following info:
Front and Wheel sizes and offsets?
Confirmation that the TPMS sensors included function?
May I pick the wheels up rather than have them shipped? (I guess you are east coast, based on the Wegmans in the image, I am in Texas)
Which Contis' specific are currently mounted on the wheels?
Are wheel lugs included?
Thank you
Sam
Thank you
Sam
Thank you
Sam
Thank you
Sam
I'm located in south jersey, about 30 minutes from Philadelphia. Pick up is fine, and I'll adjust the price accordingly.
I have a set of lugs that I can toss in.
Re:wheels
Any idea if these will cause an issue on a 2012: W212 - E350 sedan. I am concerned the rears might rub based on the 40mm offset. Stock wheel is 8.5" wide with a 48mm offset.
I would think so, but I'm not 100% sure. They would be closer to the fender by about 2.7 cm (8mm + .75"). You can measure your current clearance from the fender to tire to verify the fitment. Anything more than 3cm and you should be fine.
Offset issue
I think the rear offset will leave the face of the wheel further out than the rear fender, not really where I was looking to go.
Thank you for the energies spent though, good day
Sam
Sam
