Set of 4 HRE FF15 wheels w/Michelin PSS II tires
Set of four 19" HRE FF15 lightweight flow-formed wheels mounted with Michelin Pilot Super Sport II tires, 245/35/19 & 275/30/19. Less than 1500 miles. TPMS sensor valves. Includes [2] 20mm billet spacers and extended lug bolts to increase front track if desired.
Will fit C/E/SL class sedans, coupes, roadsters. Will NOT fit AMG models with carbon ceramic brakes [insufficient back-spacing to clear front rotors]. Can ship on pallet. $3200
East Syracuse NY. 3.5 hr. drive from you [I was up to your neighborhood Labor Day wkend.]. If you want them shipped I can get a quote from the carrier we use at work. Just give me a ship-to. There will however be an issue with GST and PST if shipped.
Thanks,
Robin
Offset front (8.5" Wide, 47mm, rear 9.5" wide 45mm offset, should be fine if. You have std. Brake system. If CCB system perhaps not because caliper size is bigger. Stock OEM Offset is 45mm front, 54mm rear. These were on a'15 E550 coupe which is a C207 platform. At stock ride height, no fender flares (as the AMG C63 has), there was no rubbing, even at full-lock wheel angles.
Will fit C/E/SL class sedans, coupes, roadsters. Will NOT fit models with carbon ceramic brakes [insufficient back-spacing to clear front rotors]. Can ship on pallet. $3000
