W203 Technical Service Bulletins
2001 C240 Sedan
General Recalls
TSB Number & Issue Date TSB Title
2000110005 DEC 00 Campaign - Accelerator Pedal Value Sensor, Failure
Service Bulletins
P-27_55-50A FEB 05 A/T - Harsh Engagement/Buzzing Noises
P-83_30-74A FEB 05 A/C - Musty/Moldy Odors
P-72_29-39A JAN 05 Body - Front Power Window Motor Locks Up When Closing
P-82_10-398A JAN 05 Lighting - License Plate Bulbs Burned Out
P-54_21-133 JAN 05 Lighting - Trunk/Cargo Light Inoperative
P-54_21-121 JAN 05 Lighting - Brake/Park Lamps Flicker With Engine ON
P-30_30-61 DEC 04 Cruise Control Inoperative
P-82_10-419 DEC 04 Lighting - Condensation in Headlamps
P-54_21-124 DEC 04 Lighting - Headlamps/IP Lamps Flicker
P-54_21-126 DEC 04 Power Locks - Central Locking System Inoperative
P-32_25-19 DEC 04 Suspension - Shock/Strut Replacement Guidelins
P-18_00-17C DEC 04 Engine - Approved Engine Oils (Addition)
P-15_40-54 NOV 04 Charging System - Insufficient Charging
P-54_21-119 OCT 04 Lighting - Tail/Brake Lamps ON Continuously
P-27_00-47A OCT 04 A/T - 722.6 Oil Leaks From Electrical Connection
P-88_30-36 OCT 04 Body - Scraping Noise From Transmission Tunnel Area
P-77_10-24 OCT 04 Body - Sliding Roof Water Leaks/Rattles
P-72_00-33 SEP 04 Body - Front/Rear Window Knocking Noise When Operated
P-82_10-376 SEP 04 Lighting - Xenon/Bi-Xenon Headlamps Not Functioning
P-82_62-391 SEP 04 Audio System - Comes ON at Maximum Volume
P-82_30-366 SEP 04 Wipers/Washers - Wipers Chatter/Noisy After Blade Change
P-82_20-370 SEP 04 Lighting - Dome Lamp Won't Come On
P-33_15-15 AUG 04 Steering/Suspension - Torque Strut Replacement Parts
P-82_00-260A AUG 04 Audio System - CD's Won't Play or Eject
P-68_20-29 AUG 04 Interior - Console/Armrest Lid Rubbing Noise
P-83_00-70 AUG 04 A/C - Inoperative/Codes Set/AC OFF Lamp Illuminated
P-91_60-65B JUL 04 SRS - Warning Lamp ON/DTC's B1035/B1037/B103B/B1039
P-77_20-26 JUL 04 Body - Sliding Roof Excess Lift Control Feature
P-68_50-24 JUN 04 Interior - Sunblind Chafe Guard/Loose
P-83_40-71 APR 04 Climate Control - Heating and Cooling Set-Points
P-46_20-16 APR 04 Steering - Leaks at Line/Rack Housing Connection
P-33_10-11 APR 04 Suspension - Rumbling Noise Driving Over Rough Roads
S-07_61-039A MAR 04 Engine Controls - DTC Trouble Shooting
P-00_45-77 FEB 04 Interior - Squeaking/Creaking Noise Kit
P-82_95-305 FEB 04 Emergency Contact/Alarm System - System 'Runaway'
P-33_15-10 FEB 04 Steering/Suspension - Alignment Requirements
S-01_30-15 FEB 04 Engine - Cylinder Wall Damage Assesment
S-49_10-08 FEB 04 Exhaust System - Rattling/Hissing/Humming Noises
P-40_10-43 JAN 04 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
P-47_10-27 JAN 04 Fuel System - Fuel Filler Cap Hard to Remove/Install
P-18_00-20 DEC 03 Engine - Oil Sludging Damage/Class Action Settlement
T-18_00-21 DEC 03 Engine - Oil Sludging/Consumption Diagnosis & Repair
S-18_00-16A DEC 03 Gasoline Engine - Oil Sludging
S-54_21-101 OCT 03 Engine Controls - ECM Flash Process Change
P-82_60-292 SEP 03 Audio System - Volume Knob Damaged
P-62_00-06 SEP 03 Body - Water Leaks Into Front Footwells
P-82_85-288 SEP 03 COMAND(R) System - Unable to Enter New Destination
P-80_57-24 SEP 03 Drive Authorization System (DAS) - Component Diagnosis
P-32_20-17A JUL 03 Suspension - Front End Knock/Rumble on Rough Roads
P-07_07-34 JUL 03 Engine Controls - MIL ON/Multiple DTC's Set
P-82_85-264 JUL 03 Navigation System - Inoperative/Erroneous Guidance
P-14_30-15 JUL 03 Emissions - MIL ON/DTC P2003 Stored in Memory
P-82_10-195C JUL 03 Lighting - Front Turn Signals Inoperative
P-20_10-23 MAY 03 Cooling System - Water Pump Leakage
P-82_70-222 MAR 03 Cell Phone - Phone Won't Fasten Into Cradle Holder
P-67_00-09 MAR 03 Body - Windshield/Rear Glass Body Seam Corrosion
P-80_57-20 FEB 03 Audio System - RF Interference Explanation
P-46_20-10 FEB 03 Steering Rack - Connector Leaks
P-82_10-217 JAN 03 Lighting - Parking/Tail Lamp Bulbs Inoperative
P-32_25-13 JAN 03 Suspension - Rumbling Noise From Rear Axle Area
P-83_55-65 DEC 02 A/C - Compressor Cycles Frequently
P-82_85-210 NOV 02 Navigation/GPS System - Various Malfunctions
P-82_62-169B OCT 02 Audio System - Various CD Player Malfunctions
P-26_50-01 SEP 02 M/T - Assembly Precautions/Recommendations
P-82_85-198 JUL 02 COMAND(R) System - No Sound/Whistling
P-91_60-53 JUL 02 SRS System - SRS Lamp ON/DTC's B1058/B2DB0
P-18_40-18A JUL 02 Engine Controls - 'Engine Oil Level Above Max' Displayed
P-82_95-164A JUL 02 Keyless Entry - Tele Aid(R) Remote Unlocking Inoperative
P-68_20-14 MAY 02 Interior - Front Cup Holder Broken
P-32_20-10 APR 02 Suspension - Rear Axle Noise
P-80_35-16 APR 02 Interior - Seat Memory Key Assignment
P-47_10-25 APR 02 Instruments - Erratic Fuel Gauge Operation
2001100003 MAR 02 Campaign - ESP Module Ground Connection Inspection
P-47_10-24 FEB 02 Fuel System - Fuel Sender Identification
P-07_60-16 JAN 02 Engine Controls - Rough Idle/Hesitation/DTC's Set
P-83_30-58 JAN 02 Automatic Temperature Control - Inoperative
P-82_85-182 DEC 01 COMAND(R) System - Various Malfunctions
P-82_85-181 NOV 01 COMAND(R) System - Does Not Respond to Voice Controls
P-83_00-57 NOV 01 A/C - Windshield Fogging in Center
P-47_20-20 NOV 01 Fuel System - Replacement Fuel Pump Adapter Harness
P-80_30-13 NOV 01 Smart Key(R) - Download Time
P-82_64-175 OCT 01 Audio System - CD Changer Static/Interference
P-47_20-17 OCT 01 Fuel System - Hard Start After Fuel Filter Replacement
P-27_60-34 OCT 01 Brakes - Fault Code P2000 Explanation
P-40_10-33A OCT 01 Tires - Approved Winter/Summer Tires
P-82_62-168 SEP 01 Audio System - Poor AM/FM Band Reception
P-82_62-165 SEP 01 Audio System - Popping/Thumping From Speakers
P-82_85-170 SEP 01 COMAND(R) System - Incorrect ETA Calculation Displayed
P-82_85-171 SEP 01 COMAND(R) System - Instrument Display Not Centered
P-32_25-07 SEP 01 Suspension - Front Axle Thumping Noise on Rough Roads
P-80_57-12 AUG 01 Smart Key(R) - Intermittently Inoperative
P-80_57-11 AUG 01 Ignition System - Electronic Ignition Switch Replacement
P-91_10-50A AUG 01 Interior - Noises From Front Seat Tilt Mechanism
P-07_65-14 AUG 01 Engine Controls - Rough Idle After Coming to a Stop
P-91_10-51 AUG 01 Interior - Front Seat Head Restraint Rattles
P-77_20-14 AUG 01 Body - Panorama Roof Panel Won't Open or Move
P-88_50-24 AUG 01 Body - Trunk Lid Will Not Open
P-91_60-48 AUG 01 Air Bag System - Side Impact Sensor Replacement
P-47_30-15 AUG 01 Emissions - OBD Shut-Off Valve Clicking Noises
P-68_10-12 AUG 01 Body - Noises From Right A-Pillar Area
P-62_10-02 AUG 01 Body/Cooling System - Upper Radiator Mount Bolts Break
P-47_25-14 AUG 01 Emissions - Evaporative Purge Valve Ticking Noise
P-72_10-21 JUL 01 Body - Door Hinge Check Noise
P-30_20-06 JUL 01 Fuel System - Accelerator Pedal Squeaks
P-82_64-138B JUN 01 Cellular Phone - Voice Recognition System Installation
P-54_10-053 MAY 01 Battery - New `Fleece' Battery Technology
S-00_00-072 MAY 01 Emission/VIN Label - Availability
S-58_091A MAY 01 Special Tool - Universal Valve Spring Tool
S-05_010A MAY 01 Tools - Universal Valve Spring Tool
S-58_20-93B APR 01 Fender/Interior/Fascia Cover - Availability
S-58_00-118 MAR 01 Engine Oil - Approved Evacuation Equipment
S-00_40-071 FEB 01 Synthetic Oil Recommendations - For FFS Vehicles
S-40_10-036 FEB 01 Tires - Maintenance & Inspection
S-60_004A DEC 00 Body/Frame - Dedicated Straightening Equipment
S-58_094A DEC 00 Chassis/Frame - Dedicated Frame Straightener
S-60_00-012 DEC 00 Special Tool - M20 Resistance Welder
S-58_30-103A DEC 00 Special Tool - Resistance Spot Welder
S-58_30-115 DEC 00 Special Tool - Resistance Welder
S-60_00-008A DEC 00 Special Tool - Spot Welder
S-40_10-034 DEC 00 Tires - High Performance Tire Storage
P-91_60-46 OCT 00 Rear Door Airbag - Deactivation/Activation
P-40_10-033 SEP 00 Tires/Snow Chains - Factory Approved Specifications
S-82_70-136 AUG 00 Timeport Portable Telephone Programming
P-58_40-113 JUN 00 Tools - Dedicated Frame Straightening Equipment
P-60_10-11 JUN 00 Tools - Frame Straightening Equipment
2001 C320 Sedan
General Recalls
Service Bulletins
2002 C230 Kompressor
Safety Recalls
2001090003 FEB 02 Recall - Right Rear Seat Belt Latch Replacement
General Recalls
2001110003 MAY 02 Campaign - Intake Air Hose Replacement
Service Bulletins
P-77_20-27A MAR 05 Body - Panorama Sliding Roof Noises
P-05_20-12A MAR 05 Engine Controls - MIL ON/Various Codes/Oil Leaks
P-05_20-14 NOV 04 Engine - Rattling Noise on Start-Up
P-42_45-23F AUG 04 Traction Control/ABS - Codes C1140/C1145 Set
P-07_00-28F FEB 04 Engine Controls - Lack of Power/Hesitation/MIL ON
P-05_20-11 DEC 03 Engine Controls/Electrical - MIL ON/Various Codes Set
P-27_19-35A JUL 03 A/T, Brakes, Traction Control - False DTC's Stored
P-42_45-19A JUL 03 A/T, Brakes, Traction Control - False DTCs Stored
P-47_10-26A APR 03 Instruments - Incorrect Fuel Gauge Readings
P-82_62-224A MAR 03 Audio System - Insufficient Bass Range Adjustment
P-82_30-234 MAR 03 Wipers/Washers - Wiper Blade Hits 'A' Pillar
P-67_20-08 NOV 02 Body - Tailgate Lower Plastic Panel Precautions
S-82_70-135B OCT 02 Fiber Optics System - Configuration/Version Coding
S-82_85-205 SEP 02 COMAND(R) System - Various Malfunctions
P-88_79-30A JUL 02 Body - Exterior Mirrors Move Slightly Over Time
S-82_70-179A FEB 02 Cellular Phone - V60 Programming Instructions
P-07_61-15 NOV 01 Emissions - Check Engine Light ON/DTC's P2036/P203A Set
2002 C240 Sedan
Service Bulletins
S-07_61-27A MAR 03 Engine Controls - ECM Reprogramming Procedure
P-77_20-18 OCT 02 Body - Sliding Pop-Up Roof Reverses When Closing
P-72_20-24 AUG 01 Body - Tailgate Spoiler Loose
P-99_00-265 JUL 01 Vehicle - Technical Information Update Announcement
2002 C320 Sedan
Service Bulletins
2002 C320 Wagon
Service Bulletins
P-82_35-237 APR 03 Wipers/Washers - Rear Washer Nozzle Misadjusted
P-68_50-16 FEB 03 Body - Luggage Compartment Cover Does Not Fit Correctly
P-82_35-220 JAN 03 Wipers/Washers - Windshield Washer System Leaks
P-68_30-13 AUG 01 Interior - Left/Right Rear Trim Panel Pushbutton Loose
2003 C230
General Recalls
2003030009 APR 04 Engine - Air Intake Duct Not Connected to Cover Cap
Service Bulletins
P-07_61-46 MAR 05 Engine Controls - MIL ON/DTC P201A/B/Rough Running
P-27_60-43 JAN 05 A/T - Rough Converter Engagement/Droning/Buzzing Noise
P-82_70-346B NOV 04 Cell Phone - Inoperative/Locks-Up
P-05_20-13 OCT 04 Engine - Rattling Noise on Start-Up
S-07_61-38F OCT 04 Engine/Transmission Controls - SCN Coding
P-82_30-399 OCT 04 Windshield - Blistering Near Rain/Light Sensor
P-09_00-18 SEP 04 Fuel System - MIL ON/DTC's P2029/P0172/P201C Set
P-01_40-14A JUN 04 Engine - Oil Leak Through Cylinder Head Bolt Thread
P-91_60-74 MAY 04 SRS - Coding Unnecessary
P-82_60-303 MAR 04 Audio System - Satellite Radio Installation
P-82_00-228B FEB 04 Audio System - Mutes Randomly
P-82_30-316 DEC 03 Wipers/Washers - Erratic Intermittent Wipe Explanation
P-82_30-279B NOV 03 Wipers/Washers- Poor Wiper Performance
P-07_61-037A NOV 03 Engine Controls - Cold Start Idle Fluctuation/No DTC's
P-82_70-284 AUG 03 Cell Phone - Voice Activated Cell Phone Installation
2003 C230 CL
Safety Recalls
2003120006 JAN 04 Recall - Seat Belt Buckle Replacement
Service Bulletins
2003 C240 4Matic Sedan
Safety Recalls
2003080003 AUG 03 Recall - Steering Coupler Pinch Bolt Torque
Service Bulletins
P-54_30-73A JUN 03 Instruments - Electrical System Voltage Displayed
S-07_08-001 JUL 02 Engine Controls - Software Calibration Number Coding
2003 C240 4Matic Wagon
Safety Recalls
Service Bulletins
2003 C240 Sedan
Safety Recalls
Service Bulletins
2003 C240 Wagon
Safety Recalls
Service Bulletins
2003 C320 4Matic Sedan
Safety Recalls
Service Bulletins
2003 C320 4Matic Wagon
Safety Recalls
Service Bulletins
2003 C320 Sedan
Safety Recalls
Service Bulletins
2003 C320 Wagon
Safety Recalls
Service Bulletins
2004 C230
General Recalls
Service Bulletins
P-27_60-44 SEP 04 A/T - Implausible Downshifts
P-54_10-116 JUL 04 Electrical/Battery - Solar Charging Panel Installation
2004 C230 CL
Safety Recalls
Service Bulletins
2004 C240 4Matic Sedan
Service Bulletins
P-18_20-22 SEP 03 Engine - New Oil Filter Requirements
2004 C240 4Matic Wagon
Service Bulletins
2004 C240 Sedan
Service Bulletins
2004 C240 Wagon
Service Bulletins
2004 C320 4Matic Sedan
Service Bulletins
2004 C320 4Matic Wagon
Service Bulletins
2004 C320 CL
Safety Recalls
Service Bulletins
