Old 06-29-2015, 03:28 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
DIY: Audio 10 Install Pics / W203 ('01-'04) Center Console Removal Instructions
Rating: Thread Rating: 9 votes, 5.00 average.
Old 08-11-2016, 03:30 PM
  #151
Edmu's Avatar
2004 C Class
No air cond. air flow to center console
After I removed the factory radio, and replaced it with an aftermarket unit, the a/c control don't change the airflow. All I get is hot, cold or fan air out of the top (windshield) slots, and the bottom (floor). No air coming out of the center and side vents.
The air flow knob just seems to be disconnected.
I removed that trim panel several times to make sure that all the cables are connected. Two harnesses on top, and a large at the bottom (which I did not remove). The two on top which I disconnected and connected again only fit in their two female counterparts (there are two additional open connectors on their side for which I did not find any cable to attach.)
My car: 2004 C class with manual a/c (no automatic climate control).
The scanner gives the following fault codes:
M2/5
M2/8
M2/10
M2/19
M2/6
M2/7
How do you reset a manual climate control? (2004 C Class)
Old 08-11-2016, 03:38 PM
  #152
VVF
VVF's Avatar
2005 C230K(sold), Mk7 Jetta
What do you mean by manual? I thought they were all electronic.
https://mbworld.org/forums/c-class-w...g-hissing.html
Old 08-12-2016, 12:17 AM
  #153
Edmu's Avatar
2004 C Class
There was a more expensive model with digital display and controls, known as the automatic climate ctrl. Mine uses analog knobs and push buttons. No digital display.
Old 06-20-2019, 03:33 PM
  #154
Roseleeclose's Avatar
2000 W203 C180 Saloon
Very good instructions, thanks. Helped me a lot on my UK year 2000 C180 Classic (no silver dash) . I have the Audio 10 HU that lights up but no sound . Ben trying to get the 6 CD changer out from glovebox but no joy. Can see what appear to be 2 push clips by shining torch up from inside glovebox but no success. No Torx 20 screw on mine as many forum members have mentioned.
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
Quick Reply: DIY: Audio 10 Install Pics / W203 ('01-'04) Center Console Removal Instructions
