HELP PLEASE C240
Old 02-19-2017, 02:21 PM
Jane2's Avatar
2004 C240 4 Matic
Exclamation HELP PLEASE C240
Hi everyone...new member here. Just spent all my money to by a 2004 C240 4 Matic from a guy who seemed trust worthy! Afterwards I smelled gas on day 1. I brought it to a Mercedes dealer and they said it was the sending unit. They wanted $1700 to fix!! Don't have it so this girl is going to attempt changing it herself! I bought the unit and it will be here Wednesday. Can anyone tell me where it is located? I saw a video that said it was behind the back seat...? Is that true? Thanks! Any help with this adventure would be appreciated! Tutorial?
Old 02-20-2017, 09:53 AM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
moved to W203 forum...
on W211, it's under the rear seats... so i assume it's similar for W203...
Old 02-21-2017, 08:40 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
I looked it up and it is the in tank unit. The w211 pump is the same setup and there are tones of threads about changing it since it was a faulty part from the factory. Unfortunately our cars were not covered in the recall. I just did this on mine so if you get stuck let us know.
Old 02-21-2017, 08:31 PM
Jane2's Avatar
2004 C240 4 Matic
I did a search but don't see anything? Because I'm new to this...someone suggested a forum W211 but when I clicked on it...it was advertisements from Amazon? Can someone send me a tutorial or direct me in a more specific way please? Thanks!
Old 02-21-2017, 09:51 PM
RedGray's Avatar
2005 C230K Sport Coupe
Near the top of the forum page, click on Search
https://mbworld.org/forums/search.php
Then, on the search page..
  1. In the field
    Search by Keyword
    Keyword(s)
  2. Type
    fuel pump
  3. In the field: Search in Forum(s)
    Scroll down and chose: C-Class (W203)
  4. Click on the button labeled:
    Search Now
You should get results similar to the following search link:
https://mbworld.org/forums/search.php?searchid=18347202
Old 02-21-2017, 09:55 PM
RedGray's Avatar
Here's a thread that has good info and attachments:
https://mbworld.org/forums/c-class-w...-tank-now.html
Here's a link to a youtube search:
https://www.youtube.com/results?sear...w203+fuel+pump
Old 02-23-2017, 03:59 PM
Russell Ormerod's Avatar
not a merc
Here's a good tip.. don't buy a Mercedes with the last of your money!
Old 04-02-2017, 06:49 PM
craiger13's Avatar
c300 4matic
Hey guys I am asking for a friend he has a c230 sport he is losing power and his engine light comes one he also experiences problems like high revs like something is wrong with the trans etc, he said that this happened before but they charged him 1700 dollars for his cam shaft I read somewhere that it could be a vacuum hose thing any ideas??
Old 04-02-2017, 08:52 PM
evannguyen's Avatar
1999 & 2005 C230 Kompressor
Invest in a code reader unit first to figure out what is wrong.
Old 04-03-2017, 03:01 AM
RedGray's Avatar
You've been on the forums for a while, and have had an MB for a while.
Yet, you didn't give critical important information.
What year is the car?
What engine is in the car?
What country is the car in/from?
The M271 4-cylinder has a problem with the "$17 hose" under the intake.
Actually, all of those hoses should be changed.
For a DYI, also use thermo-shield on the hoses. Imho, the dealerships should do that also.
Fwiw, hoses deteriorating from heat is common in "older" cars (10+ years).
Often, it's from the lack of proper heat shielding from the factory - to save money.
