C63 Diffuser w/OEM C350 Tip (Quad) Install & *Pics
Old 04-18-2014, 01:25 PM
  #126
aznmode's Avatar
2010 c300
Originally Posted by TheRulesLawyer
Just finished this up on my 2012 c350.
The AMG brackets and the originals *have* to be the same. Don't waste money on them if you have a facelift model. Its a pita to get the diffuser started coming off, easiest to pry from the inside near one of the exhaust pipes I found. The ebay h style tips are a little on the long side, but they can be but no problem. If you want them to stick out like an inch, no problem. Welding them in was about $100. You can get the same tips on aliexpress for just over $200 instead of the $285 or so on ebay. I'm using the OEM C63 diffuser.
Rear shot.
Tips. You can have them mounted in further if you like.
Nice. Not a bad price for the quad tips. I was concerned about buying non oem tips as I've read some of the H tip one rusts over time. Are the oval tips in this thread the same ones you have? 2 members have reported rust in the thread. I'm hoping they're not the same as I might bite the bullet on the ones you have. If you can post link that would be great. TIA
https://mbworld.org/forums/e-class-w...e63-style.html
Ebay listing which uses the same images as the ones on the thread so I can only assume they're the same source.
http://www.ebay.com/itm/Mercedes-Benz-S-E-CLS-W212-W221-C219-C207-C63-Style-Quad-Exhaust-Tips-AMG-/331175406291?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d1b97aad3&vxp=mtr
Old 04-18-2014, 01:36 PM
  #127
TheRulesLawyer's Avatar
C350
Mercedes Benz s E CLS W212 W221 C219 C207 C63 Style Quad Exhaust Tips AMG | eBay
Those look like the same ones I ordered. All the ebay tips are shipping from China and I suspect they all come from the same place. Here's the seller I got mine from.
http://www.aliexpress.com/item/high-...685960099.html
There is also a Y pipe design out there (and they all look the same). From what I've seen those are a more difficult install.
Old 04-18-2014, 01:44 PM
  #128
aznmode's Avatar
2010 c300
Thanks. Looks to be the same. Dang it. Ya the Y pipe ones won't be a direct weld. So I stay away from those.
Old 04-18-2014, 01:58 PM
  #129
C350
There was one guy who bought extra stock c300/350 tips and had a custom h pipe welded. Might be an option for you. Maybe you can find a pre fabbed h pipe and have those welded on to save money.
Old 04-18-2014, 02:20 PM
  #130
aznmode's Avatar
2010 c300
I actually have 2 extra oem tips that I'm going to get welded to the existing but an H pipe has to be fabricated just like what the OP did. The issue I'm having is I can't find a shop in my area that's done it before so I'm kinda stuck. The already made H pipe is the easiest way to go but I don't want it to rust down the road. So for now I'm just running the quad diffuser with the stock dual tips.
Old 04-22-2014, 02:07 PM
  #131
aznmode's Avatar
2010 c300
Rear shot.
Out of curiosity, how long did it take for you to get the tips from the day you placed the order?
Old 04-22-2014, 03:16 PM
  #132
C350
Around 2 weeks. On the long side of the estimated range.
Old 04-22-2014, 04:47 PM
  #133
aznmode's Avatar
2010 c300
That's actually pretty good. I was thinking this might be a good route to go just in case I want to go back to stock, they can just weld the OEM back on where it was originally cut. I assume they cut right at the exhaust and welded this on?
Old 04-22-2014, 05:02 PM
  #134
C350
They cut right at the muffler and weld a pipe fitted to the ID of the tips to the muffler, slide the tips on and then weld it in position. I had them take about 1/2" off the h pipe length to get it where it is. You could probably reinstall the old tips in a similar way if you like.
Old 04-22-2014, 06:09 PM
  #135
aznmode's Avatar
2010 c300
I see so the tips pipes are wider so it goes over the existing pipe after its cut. Thanks for info. This helps a lot in my decision.
Old 04-23-2014, 03:31 PM
  #136
papashango's Avatar
This and that.
I have a OEM C63 AMG diffuser with brackets if someone is interested in purchasing it. I am located in Calgary, Canada and will ship it out from here. PM if interested.
Also have two OEM exhaust tips from a C350.
Old 04-25-2014, 06:05 PM
  #137
aznmode's Avatar
2010 c300
Thanks for your help and the link to the tips. I just bought them. This broadens my muffler shop selection. . But hopefully I won't have any rust issues down the road.
Old 05-02-2014, 08:10 PM
  #138
aznmode's Avatar
2010 c300
That was quick. I got them in 7 days. Finally I can check this mod off my list
Old 05-02-2014, 08:29 PM
  #139
aznmode's Avatar
2010 c300
Do you mind taking a side view or straight top view picture. I just wanted to see how much 1/2 cut will stick out. I'm leaning more towards flushed as possible so I would assume I would need a 1 and 1/2 cut.
Old 05-02-2014, 08:48 PM
  #140
C350
I wouldn't tell them a specific length right off the bat. Once they are ready to weld in place you should have a look and give feedback.
C63 Diffuser w/OEM C350 Tip (Quad) Install & *Pics-g1tnas4.jpg
C63 Diffuser w/OEM C350 Tip (Quad) Install & *Pics-zkmdore.jpg
Old 05-02-2014, 10:19 PM
  #141
aznmode's Avatar
2010 c300
Wow that actually looks perfect. Maybe I'll do 1/2 too. Thank you!
Old 05-08-2014, 08:02 PM
  #142
aznmode's Avatar
2010 c300
Update: Got the tips welded today. I wanted it just a tad more in but the bend on the left tips was hitting part of the frame so I didn't have much choice. Interestingly, they decided to put a pipe inside for support rather than putting pipes over. So basically <tips> <smaller pipe> <exhaust>
Old 05-09-2014, 01:07 AM
  #143
C350
Looks nice. The smaller pipe inside is the same way they did mine.
Old 05-13-2014, 03:19 PM
  #144
MERVelous's Avatar
C350
I'm interested in buying just the diffuser. How much?
Old 03-09-2015, 12:28 PM
  #145
nicomunozm's Avatar
2010 mercedes benz c300
where did you get it and how much was the diffuser, I have a 2013 c350 and I think your car looks very nice, thank you
Old 03-09-2015, 04:48 PM
  #146
C350
Diffuser/brackets
http://www.ebay.com/itm/2012-2013-MERCEDES-W204-C63-SEDAN-ORIGINAL-AMG-REAR-DIFFUSER-C250-C300-C350-NEW-/360509893429?pt=Motors_Car_Truck_Parts_Accessories&hash=item53f0106b35
Quad tips
Old 03-21-2015, 01:06 PM
  #147
nicomunozm's Avatar
looks good!!! great job, I have tips from my c300, didn't get rid of them, youjust gave me a great idea for my c350 just ordered my c63 rear diffuser and I will do what you did with your car looks hot, will post pics as soon as I get it done
Old 12-08-2015, 07:54 PM
  #148
MercMate's Avatar
'11 C250 4Matic MagnaFlow X-Pipe
Hey how long is the pipe you had made for the tips? and what are the in/out diameters? how much did it cost to get the pipe made and to be welded on? im really interested in doing this, just need to know the measurements and whatnot of the pipe, thanks
Old 12-09-2015, 02:28 PM
  #149
C350
Install was about $100. As for the rest, I had about 1" cut off the pip coming off the tips. They welded in a collar to attach. Basically I brought the tips to them, said weld these on. They called me out to look at the, told them to make them more inboard. They cut some off and welded. I paid $100. Its more a matter of how far you can bring them in rather than adding pipe. Someone else mentioned they can only be brought in so far without risking rubbing on the frame.
Old 05-05-2022, 12:36 PM
  #150
StraightWisdom's Avatar
2010 C300
Hi,
Can anyone confirm if the "A" makes a difference in the part# for the rear diffuser
A204 885 45 25 or 204 885 45 25 = same thing? or do I need to make sure there is the "A"
Quick Reply: C63 Diffuser w/OEM C350 Tip (Quad) Install & *Pics
