Mother of all Fluids and Service Interval
Old 06-25-2015, 01:26 PM
white46's Avatar
08 C300
  1. Engine Oil
    Type: 272
    Interval: 10K mile or once a year
    Capacity:
    • RWD 8.5 US qt. (8.0 L)
    • AWD 7.4 US qt. (7.0 L)
    Note: You can either drain from pan or suck by dipstick guide. I prefer sucking because it's just easier.
  2. Automatic Transmission
    Type: 722.9
    Interval: 39K mile or 60K Km
    Capacity:
    • C250 RWD 9.0 US qt. (8.5 L)
    • C250 AWD 10.3 US qt. (9.7 L)
    • C300 C350 RWD 9.5 US qt. (9.0 L)
    • C300 C350 AWD 10.5 US qt. (9.9 L)
    Note: Make sure you drain TC as well!
  3. Manual Transmission
    Type: 716.6
    Interval: Lifetime
    Capacity:
    • C250 1.3 US qt. (1.2 L)
    • C300 1.6 US qt. (1.5 L)
    Note: Very limited resources.
  4. Rear Differential
    Interval: Lifetime
    Capacity: 1.06 US qt. (1.0 L)
    Recommended to replace Fill/Drain plug during servicing. Both plugs shares the same part# 3529970032. Torque 50Nm. Use blue loctite during installation.
    Note: Although MB doesn't mention service interval for differential fluid and so-called lifetime, I assume 100K mile is good mark to flush.
  5. Front Differential for AWD
    Interval: Lifetime
    Capacity: 1.16 US qt. (1.1 L)
    Note: Although MB doesn't mention service interval for differential fluid and so-called lifetime, I assume 100K mile is good mark to flush. Also there isn't separate transfer case. I believe the transfer case is integrated to transmission. Maybe this is reason why we see many AWD auto tranny failure?
  6. Power Steering
    Interval: Lifetime
    Capacity: 0.85 US qt. (0.8 L)
    Note: I don't trust "Lifetime fluid". I consider flushing at 100K miles.
  7. Brake Fluid
    Interval: Every 2 year
    Capacity: 0.53 US qt. (0.5 L)
    Note: Although specification calls DOT 4+, I've used ATE DOT 4 without any problem. Also brake fluid service interval is time driven. Not mileage.
  8. Antifreeze/Coolant
    Interval: 143K mile or evey 15 years
    Capacity: 5.07 US qt. (4.8 L)
    Note: This is such a long interval for coolant. Having said that, I can almost guarantee that thermostat will fail before that mark comes. You can flush it that time.
Please let me know if any correction is needed!
The following 2 users liked this post by white46:
Dmurph (05-22-2023), edgalang (11-01-2017)
white46's Avatar
08 C300
Bonus. Few regular maintenance item service interval.
  1. Spark Plug
    Interval: 91K mile or every 5 years
    OE:
    • NGK PLKR 6A
    • Bosch Platinum Y 7 MMP 33
    Note: Tightening torque: 15 – 22 lb-ft (20 – 30 Nm)
  2. Engine Air Filter
    Interval: 26K mile or evey 2 years
  3. Cabin Air Filter
  4. Fuel Filter
    Note: This is quite long interval. I'm not sure whether I want to push that far.
  5. Engine Drive/Serpentine belt
    Interval: couldn't find
    Note: Mare sure you replace idle pulley too because it's known failure on 272 engine.
chrisridebike8 (07-09-2016), Dmurph (05-22-2023)
Old 06-25-2015, 06:02 PM
a1rh3adsz's Avatar
'06 mz3, '12 R6, '09 W204, '02 A4 B6, '14 IS350
just curious does "TC" stand for "torque converter" or "transfer case" ??
Old 06-25-2015, 07:16 PM
white46's Avatar
08 C300
torque converter.
There is no separate transfer case for AWD w204 models.
dennish (07-06-2016)
Old 06-27-2015, 11:56 AM
Trancebolt's Avatar
w212 E350 Bluetec & Mk7 GTI Sport
Thanks alot sir, this is a good guide here. Appreciated
Old 07-02-2015, 02:36 PM
white46's Avatar
08 C300
No problem. Glad I could help.
Old 07-02-2015, 11:04 PM
95Sinned420's Avatar
2016 S550
For the transmission, I believe starting 2011 some models use the updated tranny fluid which has the change interval increased to 79k?
Old 07-03-2015, 02:14 PM
Demvang's Avatar
2011 C300 4Matic Sport
I think 26k miles for air filter is a little bit early. Usually 30k for a single air filter, 2 air filters for 40k according to Mercedes is appropriate.
Thanks for the info
Old 07-06-2016, 08:39 PM
Big Daddy's Avatar
C220 CDI SLK 200
Thanks for the info
Depends on where you live and what types of roads you drive on
Did a lot of country driving dirt roads and the air filter was clogged 15K after I replaced it
Inspect it every time you service the car
Old 07-07-2016, 11:57 AM
doxycat's Avatar
C300 '08 Sport sedan
This is one of the most useful topics i found
Quick Reply: Mother of all Fluids and Service Interval
