C300 4matic New Rims
SL600
I am looking into purchasing new rims and need help determining if these will fit correctly.
http://www.victoriatire.com/wheel_IN...0SATIN%20BLACK
19x8.5 in front, 19x9.5 in rear is what I heard for 19 inch
But I am considering 18 inch and am not sure what sizes I should use to fit with the stock 225/40-18 front and 255/35-18 rear.
They do not have 18x8.5 or 18x9.5,but have 18x8 and 18x9
18x8 on front and 18x9 at the back will be perfect just make sure you do not go lower than 45 for the offset or you might rub specially at the front.
You can use 225-235 (max) for the front and 255 at the back. My setup is square 18x9 et45 then front rubber is 245 then back is 255.
