Tail Pipe Soot
2012 C63
Tail Pipe Soot
Ever since my car was new(only 500mi on it now) I've noticed an excessive amount of soot on the right tailpipe tips while the left side has hardly any.Oil level is ok,no cel's,car seems to run ok,although I'm taking it easy until after break in.Something causing rich fuel mixture on right side??Anyone else experiencing same problem??Thnx....
I have soot on each pipe, and have owned AMG since 2007, this is nothing to woory about. Even my C63 has more soot on one side then the other.
2010 Irridium Silver MB C63 AMG Sedan
Exhaust will take the path of least resistance. It will leave where it can. For some reason, its just leaving out of the other ports more. Drive your car more, when you get to 2500 miles, then let us know and take a look.
2017 Mini Cooper S Clubman ALL4 - British Racing Green
If only I could get flames to shoot out of my cars ***... that would solve my tailgating issues I have driving around DC :P
The real question here, is how do you clean that crap off..
kcmgt (03-21-2016)
Wheel cleaner (ones that break up brake dust) works. You can use a bit of metal polish to work the shine back in the chrome. Alternatively you can paint the tips flat black and never worry about clean them.
1 Post
2009 Barolo red C63 AMG (SOLD).13' P31 c63 coupe 2012 porsche panamera
Very common. A lot of people just leave it and think it looks good haha. Just polish it with mothers polish every once in a while and wipe it every time you wash it and it should keep the soot at bay.
C63 Black Series, Magno Alanite Grey
Best way to get the soot off is actually WEIMANS Coooktop Cleaner/Polish.
Wipes right off, like lotion on your face.
http://www.weiman.com/products/glass...p-cleaner.aspx
I have the same issue with my 09 C63 with 50k. I have seen other amg's with more soot on one tip in comparison to the other. If you pull out the plugs you will also realize that the side with more soot, the spark plugs are also darker. This usually means that for whatever reason that bank is running richer than the other bank. I have had the dealer look into this several times and they always tell me everything is running fine. I guess it maybe an amg thing
i also found a really good way to get tough stains off of the tips is using wd-40 and steel wool. all the soot comes right off and it doesnt scratch your pipes! then i polish it with mothers
(a)'12 C63 P/P, LSD, 19" m/spoke,comfort pack. (b)Astra SRI.
Cleaning exhaust tips?...Ya don't need anything flash......just a bit of household kerosene soaked in a rag....and those black deposits will disappear....instantly.
Cheers, Pickles.
Cheers, Pickles.
I clean the inside with an old wash mitt and the car soap I use to wash the car. Seems to clean up pretty easily. I get some burned on stuff on the outside of the tips that I clean up with Never-Dull wadding.
'02 E55, '03 Z4 6MT and other lesser vehicles
When using the steel wool, make sure it's 0000. As in four "aut". Available at any of the box stores.
Cheers !
Mike K.
Cheers !
Mike K.
