Longer Wheel Bolts for Spacers
Hi, I am about to order H&R spacers, but I need longer wheels bolts. I am after some good quality (10.9 grade) bolts. Is the OEM bolt 28mm?
Front - 12mm Spacer / 40mm Bolt
Rear - 10mm Spacer / 38mm Bolt
Just cant seem to find the ones I want.
Thanks.
Thanks.
The OEM are 27mm. R1.5 ball seat R14.
https://www.spurverbreiterung.de/
It`s in Germany but there you can find whatever you need.
Spacers, Bolts,...and everything also in dimensions you want.
They do it for you.
Spacers 17,3mm? No problem
They do it for you.
I got the exact thickness spacers as u, and I'm using 40mm longer ball seated bolts.. No problem with rubbing my abs mechanism in the rear (some ppl rubs).
I got my set at essexdistributors in Vancouver.
Same here - I have the exact thickness spacers (12mm front, 10mm rear) and went with 40mm black ball seated bolts.
However, my bolts did rub against the parking brake in the rear. I took them (rear bolts only) to a local machine shop to shave off 2mm and the problem went away.
I got the bolts from Chris at FXAutodesign (he is on this forum - search for "Suspension Special")
Went 12mm H&R on std rims and H&R extended bolts so there are H&R bolts available.
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
H&R or RAD are your best choices - and if you get anything else, make sure they're made of 10.1 grade steel (there is a 10.1 marking on the bolt heads). If you can't find 38mm bolts, get 40mm and get them cut by 2mm by your mechanic or a machine shop.
