Black Series brakes on C63
Hopefully I will get them on time prior to my next track day. I will share my learnings from the install, street driving and track day afterwards.
Adaptor is made and anodized. Here some weight difference:
OE C63 Steel bracket:
OE C63 BS Steel bracket:
RB Aluminum alloy bracket:
RB two piece rotor hat - C63 drum size assembled with C63BS rear disc (360x26):
Assembled weight:
Still saves you 5 lbs per rotor even oversized to 360x26mm (vs. original 330x26mm 1pc rotor)
http://www.racingbrake.com/Brake-Rot.../mb-irk-02.htm
See installation and performance review here:
https://mbworld.org/forums/c63-amg-w...eir-car-4.html
Getting ready to go to the track for the first time this season in 2 weeks - NCM (Bowling Green, KY) with NASA. Can't wait!
https://mbworld.org/forums/c63-amg-w...eir-car-3.html
Since black and non-black c63 brake pad is the same, i might throw a set of mx72 on BS for street use. It bites much better than OEM pads and much more consistent too.
Endless also has track dedicated compounds, but from Carbotech you get great pads for under 600$ per full set (4 corners) vs 1000$ with Endless. And I am going through several sets a season.
