Black Series brakes on C63
Subscribe
Oct 9, 2019 | 11:36 PM
  #101
Quote: AND his math is totally wrong.
Look at a brake rotor assembly.
Yes, the rotor ring is 390mm in diameter. But the first, call it half of the radius for easy calc is the hat. Total area is = pi *r^2. To find the braking surface area you need to subtract the hat area. So a 30mm total diameter increase should give you a massive % increase in braking surface area.
So the total 360mm rotor area is = 101,788 sq mm
A hat area of 180mm is = 25,447 sq mm
For a braking surface area of = 76,341 sq mm
Doing the same math for a 390mm rotor you get a braking surface area of = 94,013
Doing more math (I know it’s hard)....
The 390mm rotor has almost 25% greater braking surface area than the 360mm rotor
And that was using a very rough calc. The hat assembly is more like 3/5 of the total radius. I bet the true increase is something like 30%.
So the guy is just incorrect in every way possible.
It is clear too me, that you don't know the physics behind brake calculations.
Brake torque is influenced by 3 things.
1. Effective brake diameter on the rotor, which is from the center og the rotor, to mid brake pad.
2. Force applied to brake pads on rotor, by the pistons in the caliper.
3. Friction coeff.. between brake pads and rotor.
If you change only #1, and go from 360 to 390 mm. rotors, the increase in brake torque will be 8.3 % The cal looks as follows. (((390/2) - (360/2))*100) / (360/2) = 8.3%
Rotor area has only minor influence on brake torque,
I missed out on the rotor being 390 mm.
Reply 0
Oct 9, 2019 | 11:41 PM
  #102
I like my math better
Reply 0
Oct 9, 2019 | 11:48 PM
  #103
Quote: I like my math better
Guy's I don't want to take away your impression that you got way better brakes, but the physics can't be defied.
The placebo effect can be big, since common sense tells us that what we see do look a LOT bigger, therefore the brake torque MUST be a lot bigger.
Be happy with your big brakes
Reply 0
Oct 10, 2019 | 08:40 AM
  #104
Quote: Guy's I don't want to take away your impression that you got way better brakes, but the physics can't be defied.
I don’t want to take away your impression that your math isn’t wrong and your classroom analysis of the brakes is far from reality. But it’s wrong. All of it. The big brakes are a night and day improvement, backed up by hundreds of hours on a track. Like, in real life. Not in your make believe land.
Reply 0
Oct 10, 2019 | 10:14 AM
  #105
Quote: It is clear too me, that you don't know the physics behind brake calculations.
I think your delivery got off on the wrong foot. 3 is what the larger rotor helps the most with.
For the street it's a complete waste of cheese, I agree. But for track, hands down completely worth it.
Reply 0
Oct 10, 2019 | 11:38 AM
  #106
Quote: I think your delivery got off on the wrong foot. 3 is what the larger rotor helps the most with.
Sorry to say, but you are completely missing the point I made.
The only thing I relate to is the statement that RB Brakes made that changing rotor size from 360 to 380 ( turned our to be 390 ) mm. would improve brake performance significantly.
The change in size do contribute approx 8% in brake torque, not more.
That you and others do feel that the performance of the brakes are increased beyond these 8%, is very much possible due to other factors, like increased friction coeff., better pads, higher thermal capacity, less or no fading, etc.
So, I do not question the performance of the rotors, as I don't know the remaining variables, but only stating that the change in size only contribute with approx 8%.more braking torque.
What really contributes is piston area, second, hydraulic pressure, and third, friction coeff.
That is why you often see bigger calipers than bigger rotors.
Reply 0
  #107
also factor in the leverage arm for braking related to the hub has been lengthened...... on my RS6 the 390mm Mov'it kit utterly changed the car on the track.
Reply 0
Oct 10, 2019 | 12:17 PM
  #108
Quote: Sorry to say, but you are completely missing the point I made.
You. Are. Wrong.
Like, completely. Your math is incorrect. Take your head out of your math book and go look at a rotor sometime. Round metal thing. Not the wheel but behind it.
Reply 0
Explore
Oct 10, 2019 | 01:14 PM
  #109
Quote: What really contributes is piston area, second, hydraulic pressure, and third, friction coeff.
Right, and friction coefficient is variable with heat. The ability to keep brakes cool helps prevent the decrease of friction coefficient during repeated usage which is extremely important at the track.
This car has absolutely zero issue with piston area, or hydraulic pressure. If the rotors are too fkn hot you'll just destroy the pads even faster with larger calipers.
How do you keep rotors cool? Increase the diameter, add cooling vents, or both...
Reply 0
Oct 10, 2019 | 01:16 PM
  #110
For most Mercedes owners' spirited driving style, a larger rotor can certainly extend the life of consumable such as pad & rotor, lower maintenance in brake fluid replacement and caliper rebuilt etc. due to lower service factor (run at cooler temperature in all braking conditions).
So overall they all add up to saving you time and money in the long run, although most people tend to neglect those long term benefit when making their replacement purchase.
Racing Brake Rotors after 113,556miles
https://mbworld.org/forums/w211-amg/...-556miles.html
RacingBrake is proud to serve Mercedes community with the finest brake products in the performance industry regardless you are just looking for OE replacement, or performance upgrade we have them all.
https://www.racingbrake.com/MERCEDES...com-s/6217.htm
Reply 0
Oct 10, 2019 | 03:54 PM
  #111
Reply 0
Oct 10, 2019 | 03:56 PM
  #112
https://brakepower.com/
Reply 0
Oct 10, 2019 | 04:00 PM
  #113
https://www.zeckhausen.com/catalog/i...Path=6446_6565
Reply 0
Oct 10, 2019 | 04:03 PM
  #114
https://www.cquence.net/blog/big-bra...-do-they-work/
Reply 0
Oct 10, 2019 | 04:06 PM
  #115
Quote: https://www.zeckhausen.com/catalog/i...Path=6446_6565
Exactly my point. Look at the massive differences in temp between Stoptech 332mm front vs 355mm with stock rear.
Reply 0
Oct 10, 2019 | 07:25 PM
  #116
My replaced front 8 piston calipers, I chose the same, as they brake like hell
Reply 0
Oct 10, 2019 | 08:14 PM
  #117
I don’t understand what’s happening here. But it’s weirding me out.
Reply 1
Oct 10, 2019 | 08:38 PM
  #118
amen...... Hot tub time warp I think......
Reply 0
Aug 6, 2020 | 02:53 AM
  #119
This is the most popular popular brake upgrade for C63 (08-15) to Black Series BBK.
Lots of installation with hundreds of happy customers; from street to tracks....
https://racingbrake.com/rb-2-pc-roto...howHidden=true
For the rear brake rotor, we make the rotor hat drum size to C63 so it's fully compatible with OE brake shoes, yet the disc is oversized to Black Series. The only rear BBK that's fully compatible to the original C63.
100% bolt on installation for the lasting performance and durability.
Feature & kit content:
Front kit - Reuse your OE caliper with exclusively designed caliper adaptor supplied by RB to instantly increase your rotor size from 360 to 390mm
Rear kit - Rotor is over-sized from 330 to 360mm - A pair of brand new OE "black series" rear Red caliper is included in the kit..
Car set of SS brake line - Included.
Car set of low dust, no squeaky street performance brake pads (XT910) is included.
Reply 2
Subscribe
Currently Active Users (1)
