C63 AMG (W204) 2008 - 2015
Black Series brakes on C63
Old Nov 18, 2016 | 01:57 PM
  #76
AMG3.2's Avatar
C63 AMG, P30
Originally Posted by BLKROKT
If that's the case, then my bad. But his prior post made it sound like he was sourcing the caliper brackets elsewhere, and if that's the case then IMO it's out-of-line posting inside of the RB thread. We'll see.
We'll find out I guess. I have no clue now that you bring up the point. RB won't sell just the bracket if I'm not mistaken though.
Old Nov 18, 2016 | 02:08 PM
  #77
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
That's what I've heard as well. And really, why should they? They have a BBK kit, they put a lot of work into research and development of it, so I would keep the bracket as part of the set also from a business perspective.
What I found a little messed up is the posting of plans for a potential group buy, to basically shortcut the RB BBK by purchasing the adapter elsewhere (and then I guess cobbling together the other parts from other sources), in their thread.
I mean, show a little consideration.
Old Nov 18, 2016 | 02:24 PM
  #78
gmaschine's Avatar
W463
Ooops, thought it was general discussion thread.
Didn't know it was specifically for "Racing Brake"
Old Nov 18, 2016 | 02:25 PM
  #79
AMG3.2's Avatar
C63 AMG, P30
I not only hear you, but I agree. If they don't want to sell them separately, there's no reason to push the issue. They have the right.
Old Nov 21, 2016 | 01:23 PM
  #80
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
Thank you for your understanding and support. System compatibility and performance integrity is how RB brakes differentiate from others.
Parts and idea can be copied but not knowledge and expertise.
Old Nov 21, 2016 | 09:51 PM
  #81
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
I can vouch for Racing Brake. Several years ago, I owned a 09 ML C63AMG bulldog. The previous owner had modded the Benz: resonator removal, s/w upgrade, ForgeStar 10 spoke wheels and the two-piece rotors from Racing Brake. I had several great discussions with these guys. Good Stuff!!!
Old Nov 29, 2016 | 09:12 AM
  #82
CLS550
Thank you for the endorsement. Here are some examples why Dodge Viper owners (both street and track drivers) put their trust on RB brakes because we don't just copy the parts like others we make them better - Better than OE.
Brake Job Rotor Now Contacts the Brake Caliper - RB front two piece rotors (for G1/G2) correct the OE rotor offset, so now the rotor will not contact the caliper.
Racing Brakes Rear Bias Kit Evaluation
- RB rear caliper kits correct the OE brake balance (for G3, G4, G5), so now the rear end will not wiggle when braking hard on track.
Old Dec 4, 2016 | 01:13 PM
  #83
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
The weather forecast for Cincinnati says snow and lows in the mid teens next week, so I swapped the RacingBrake front rotors out for the OEM rotors today. I am running 18 inch winter wheels and therefore I have winter tires and winter brakes, oh well.
I have been driving the RacingBrake front rotors now since March, on track days (NCM, Watkins Glen) and as a daily all the time. They sure can take a beating and are hard. As you can see from the pics, they do not wear until they become too thin. They start developing cracks (very typical for racing brakes). Over time those cracks get longer and combine. Once they reach the outer edges of the disk it's time to renew. These rotors would have lasted a bit longer, but not much.
I will get new rings over winter and put the new ones on in spring again.
By the way - in normal street driving (without beating the crap out of them on track) you wouldn't get to that condition probably ever, or at least not for years. It is extreme heat cycling that does that.
Black Series brakes on C63-2016-12-04-2012.54.31_zps7gnzltgb.jpgBlack Series brakes on C63-2016-12-04-2012.53.47_zpsjjdgynnw.jpgBlack Series brakes on C63-2016-12-04-2012.52.57_zpspmcpozmi.jpg
Old Mar 4, 2017 | 10:04 PM
  #84
JohnnyC's Avatar
2015 GLK350 & 2020 C300
interesting seeing them in use and getting worn out.
Old Sep 23, 2017 | 04:23 PM
  #85
c63panda's Avatar
2012 C63 Coupe
I just upgraded to 19's from 18's and I got a few months left before brakes. Would I need to get a 19 spare wheel for it to fit over the larger brakes? If so does anyone know a part number
Old Feb 2, 2019 | 01:38 PM
  #86
c63panda's Avatar
2012 C63 Coupe
Let's try this again. If I upgrade to these brakes, would my spare fit over them or would I need a new spare. Does the BS come with a spare, p/n?
Old Feb 2, 2019 | 02:49 PM
  #87
BLKROKT's Avatar
Spare won’t fit anymore. Get a AAA membership.
Old Feb 2, 2019 | 06:55 PM
  #88
MBNRG's Avatar
As BLKROKT mentioned, your stock non-BS C63 spare will not clear the new position of the front calipers.
I had previously asked the same question as you: https://mbworld.org/forums/c63-amg-w...imensions.html
The BS C63 spare seems to be the same as the one used in E63, etc
Old Feb 3, 2019 | 01:09 AM
  #89
c63panda's Avatar
2012 C63 Coupe
Originally Posted by MBNRG
As BLKRKT mentioned, your stock non-BS C63 spare will not clear the new position of the front calipers.
MBNRG, THANK YOU!
Old Oct 8, 2019 | 06:45 PM
  #90
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Originally Posted by RacingBrake
To be replaced by RB aluminum alloy light weight adaptor for 390mm rotor (Estd Wt: 1.3 lbs)
Is this bracket available standalone?
Old Oct 9, 2019 | 01:38 PM
  #91
gmaschine's Avatar
W463
RB doesn't sell the bracket by itself.
Luckily I have a pair for sale, PM me if you're interested!
Old Oct 9, 2019 | 01:55 PM
  #92
SLcharge's Avatar
09 SL500, 03 E320 CDI Wagon
380x28 rotors, it will be 2" oversize than OE's 330 (13"), and even bigger than black series' 360mm (14").
They will, for sure, dramatically improve your C63 both in braking performance and look.
If reusing the stock calipers, the indrease in brake torque going from 360 to 380 mm rotor is exactly 5.6%
I don't know how you define " dramatically improve your C63 braking performance " , but 5.6% is not huge too me.
It's all about looks.
Old Oct 9, 2019 | 01:56 PM
  #93
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
What about heat dissipation?
Old Oct 9, 2019 | 02:06 PM
  #94
SLcharge's Avatar
If you do track day's you will notice, but for daily driving, you will not notice any difference.
A further problem, is keeping the rotors clean. The bigger brakes will require less pedal pressure, and the rotors will slowly get a Traffic film on the surface ( pulse braking ), so that you to avoid that, have to constantly step harder on the brakes. This will also increase tire wear.
Winter driving will be even more difficult.
Old Oct 9, 2019 | 03:57 PM
  #95
BLKROKT's Avatar
Winter driving is not at all difficult with the RacingBrake BBK. That’s just retarded. In fact your entire statement above is nonsensical. Traffic film, pulse braking... GTFOH.
And it’s about more than looks. My RB front rotors survived over 3 years of hard track abuse, the rears are still going. Fantastic upgrade.
Old Oct 9, 2019 | 05:21 PM
  #96
SLcharge's Avatar
Old Oct 9, 2019 | 09:20 PM
  #97
MBNRG's Avatar
. . . 5.6% is not huge too me.
This is incorrect. It is an increase from 360 to 390mm.
In addition, ALL aspects of braking performance are significantly improved with the Racing Brake BS BBK over OEM.
Old Oct 9, 2019 | 09:25 PM
  #98
MBNRG's Avatar
Racing Brake, if you are listening, kindly requesting a Group Buy for your Black Series sized Rotors (Fronts & Rears), please!
It's time for new Rotors for many of us, especially for those who installed your bada$$ Black Series BBK
Old Oct 9, 2019 | 10:37 PM
  #99
BLKROKT's Avatar
AND his math is totally wrong.
Look at a brake rotor assembly.
Yes, the rotor ring is 390mm in diameter. But the first, call it half of the radius for easy calc is the hat. Total area is = pi *r^2. To find the braking surface area you need to subtract the hat area. So a 30mm total diameter increase should give you a massive % increase in braking surface area.
So the total 360mm rotor area is = 101,788 sq mm
A hat area of 180mm is = 25,447 sq mm
For a braking surface area of = 76,341 sq mm
Doing the same math for a 390mm rotor you get a braking surface area of = 94,013
Doing more math (I know it’s hard)....
The 390mm rotor has almost 25% greater braking surface area than the 360mm rotor
And that was using a very rough calc. The hat assembly is more like 3/5 of the total radius. I bet the true increase is something like 30%.
So the guy is just incorrect in every way possible.
Old Oct 9, 2019 | 10:54 PM
  #100
deadlyvt's Avatar
2010 C63 AMG
It’s not just that... the Caliper gets increased torque from being place further out from the center of rotation of the wheel... so you have an increase in clamping torque in relation to the hub which you will definitely notice
