C63 AMG (W204) 2008 - 2015
Transmission problems
Old 07-05-2015, 12:36 PM
Wuppi's Avatar
2013 C63 AMG Coupe
i go to the track with my C63 and have transmission problems since last year.
In Sport and Sport+ the Trani over heats and the car goes into a Limb mode.
The car was in the shop 8 times and the dealer couldn't fix it.
It there anybody else who has that problem?
Old 07-05-2015, 01:01 PM
CarHopper's Avatar
E63S | X5
What makes you so sure it's the tranny putting you into limp mode?
Old 07-05-2015, 01:05 PM
Wuppi's Avatar
2013 C63 AMG Coupe
In C mode the oil temperature stays at 117C and in Sport - + it goes up to 143C and then it goes into limb mode.
Old 07-05-2015, 01:07 PM
CarHopper's Avatar
E63S | X5
Yeah, so your oil temps are causing it, not your tranny.
So, here you go: https://mbworld.org/forums/c63-amg-w...oming-c63.html
You can get an oil cooling upgrade from the dealer. This is a known issue for people who track their car.
Old 07-05-2015, 01:12 PM
BLKROKT's Avatar
Received 2,810 Likes on 1,664 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
^ Exactly. You're running higher RPM gear changes in S+ mode, plus your car is downshifting more aggressively. Technically it's your engine oil temp, which is caused by your transmission mode selection. It's not a transmission problem.
See the thread "Keeping Your Cool!" For a solution to this on track. I have never seen limp mode.
Old 07-05-2015, 01:13 PM
ItalianJoe1's Avatar
2003 CL 600
Have you looked into adding a bigger transmission cooler?
What kind of track use, road course or drag racing?
Edit, took too long to reply lol
Any aftermarket oil cooler could be used to help out in that case, but if there's a factory solution that would be preferred.
Old 07-05-2015, 01:27 PM
Wuppi's Avatar
2013 C63 AMG Coupe
The 2014 C63 507 has a added Transmission cooler and has no problems on the track.
MB Canada has now a upgrade for my car from the racing series, but since I'm driving on the track??? The issue is who is paying?
I'm driving on Mosport in Ontario, Canada.
Old 07-05-2015, 02:38 PM
odonnks's Avatar
Ford Truck, 2014 C63 AMG 507
I didn't think the 507 received a different cooler. Where did you see that information.
Take a look at the thread BKLROKT suggested. It's a great solution.
Old 07-05-2015, 03:58 PM
BLKROKT's Avatar
This is incorrect
Old 07-05-2015, 05:24 PM
CarHopper's Avatar
E63S | X5
Here is the thread other members have referenced: https://mbworld.org/forums/c63-amg-w...your-cool.html
Old 07-05-2015, 09:03 PM
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
Another relevant thread is here:
https://mbworld.org/forums/c63-amg-w...rack-test.html
Old 07-06-2015, 07:57 PM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
An additional cooler would be fantastic, but is that correct? For Canadian 507s? Any documentation?
Quick Reply: Transmission problems
