NEED 2 throttle bodies asap
HI Guys
I need to buy 2 throttle bodies asap
Anyone have any lying around?
mr747 (06-14-2016)
Im hoping merc63 has 2 for me
I actually just sent one back monday so it should get there probably tomorrow! I sent it back only because I didnt need it. I thought the throttle ody had to be replaced, but it turned out to be a piece from the charcoal filters stuck in the TB. I would call them tomorrow or friday and asked if they got the one I sent back.
Did you start having troubles after you install the c300 calipers?? I'm asking because when I install mines and use the 15 inch wheels with the slicks the car start closing the throttles. after a few tests we realized the difference in diameter of the front and rear wheels was the problem. Run the car in dyno mode and see if the problem disappear. If yes then buy front skinny wheels for drag.
Received 2,842 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
^ 9sec car problems LOL
Mario I run 16s at the track not 15s but with c300 calipers
But I also have problems with my 19s on the street
Charlie I have sent the logs to weistec and this is there response
QUOTE
In some of the logs, we can see that one of the throttle bodies is closing earlier than the other. Since you already replaced the throttle body harness, it could be that the electronics in one of the throttle bodies is causing an issue resulting in asymmetrical response between the two. Enough of this could trip the ESP system and give a throttle body code.
another thing we see that is likely holding some of the power back is the intake MAP value is dropping to as low as 79kpa as the RPM's climb. Ideally, this should stay close to barometric air pressure when at full throttle.
The logs show barometric air pressure is 99 kpa. At that barometric pressure, an acceptable intake MAP would be at 93 kpa and higher. So when intake MAP is in the low 80' kpa, that basically means the supercharger is being "choked". going off the numbers in the log, it looks as though its enough of a "choking" to result in what would effectively be running a lower boost supercharger pulley.
Check for any kind of intake restriction (blocked or collapsing airbox inlets, dirty air filters)
UNQUOTE
I have checked for blockage and everything is ok just hoping after I replace these throttle bodies my problem goes away and my car runs normal how it should
QUOTE
UNQUOTE
Brad, the stage 3 charged c63 that i replaced the tb's on didn't throw any tb codes but kept going into limp. I don't remember the symptoms exactly but sounds similar to yours.
Either way if you get the car to Allen it's going to come back a monster.
I'm going to do some testing in 10 hrs at the track
Guys i got screwed and the throttle bodies i was supposed to buy are not good
Do you guys have any phone numbers/email address of wreckers in the states where you think i can get a good pair from
the guys on ebay are not replying to me
Part number is 1561410225 brand new is not a option
Did you call Weistec? They have to have some lying around you'd think.
Edit: Nevermind I see you were talking to them already. Forget it. Try other shops - Eurocharged, ACG, etc
^^ they dont have any good ones
thanks road
So I have the throttle fitted and the car feels better a lot better
I could only drive the car in traffic but I will get out there tonight and have a proper try hope the problem has disappeared
