How to remove xenon headlight bulb??
Old 05-17-2010, 08:35 PM
azheman's Avatar
06 CLK500, 05 ML500
I was finally able to get the small screws loosened using a small allen wrench, but can't get the orange piece to turn.
Am i doing this right? I'm trying to get it out to make sure the part # to order.
Thanks.
Attached Thumbnails How to remove xenon headlight bulb??-img00050-20100517-1730.jpg
Old 05-18-2010, 07:18 PM
tootyte36's Avatar
1998 e320
Did you try to remove the screws that are holding it in place?
Old 05-18-2010, 08:14 PM
raymond g-'s Avatar
99 E320
if that is for the OEM MB lighting system, they only made one type, and it uses
a reflector design. so the bulb would be a D2R bulb. if you only replace one,
you run the risk of having one bulb operating at a different color than the other.
so if you can afford it, buy two. OEM only used Osram or Philips brands.
i don't one one but from the looks of your photo, use a Torx bit and loosen (not
remove) several turns. then, rotate that plastic fitting CCW and it should lift
off....giving you access to the bulb.
Old 05-18-2010, 08:49 PM
Fabio D's Avatar
210 55
you don't need to unscrew the torx screws! this system are design to hold the bulb without remove nothing.. you only need to rotate the plastic yellow holder & lift off, after you would pull of the bulb.
The yellow holder sometimes is a bit hard to turn.. but don't scare it not crack if you turn them properly... turn it counter-clock to lift out
Fabio Daniel
Old 05-18-2010, 10:54 PM
raymond g-'s Avatar
99 E320
good to know, Fabio. considering that would be the only HID that I know of
which requires tools to remove the bulb...it occurred to me that the fastener
design used bordered on overkill.
Old 05-19-2010, 09:03 PM
Fabio D's Avatar
210 55
Hahahahaha is pretty easy remove the HID bulbs in this case... in the first first Gen cars (97 - 98) with the big HID ballaster you need to remove 3 x 8mm bolts to lift out the bulb.. after cars has the easy design to remove the bulbs same ase the picture
Fabio Daniel
Old 05-19-2010, 09:36 PM
waybomb's Avatar
SL600 r230, SL600 r129,, SL500 r230, ML320, C280 Sport, 190e 2.3 16V (2)
Fabio Daniel
It helps to unscrew the screws a turn or so, so it turns easy. I unloosened mine about 1/2 turn and I was still afraid I'd break the plastic. They were bother very much stuck. I unloosened another turn and only them was I able to turn the plastic retainer.
Old 02-15-2011, 02:57 AM
benz300's Avatar
the bulb has a small wire going from the base to the end. I can't remember if the wire was supposed to be on the bottom or on top when putting the bulb back in the holder... any help is appreciated. thanks.
Old 02-15-2011, 01:50 PM
Lancelot's Avatar
'01 W210 E320 CDI
It is a general misconception that the screws need to be removed or loosened! The orange-colored-piece simply snaps over pins held in place with the screws. I've replaced D2R bulbs on both first generation- and facelift W210's and all you need to do is turn the orange-colored-piece. First turn and take off the large connector on the back of the bulb, then turn the orange piece which takes some force. The base of the D2R bulb has a notch so it cannot be mounted in a wrong manner. Good luck!
Old 05-20-2012, 11:25 PM
impalaman's Avatar
2000 E320 Wagon
Thanks very much gentlemen. This helps a great deal. Off to the parts store tomorrow for a new XENON bulb. My 2000 E320 has the OEM XENON bulb option for the low beams.
Old 05-21-2012, 01:17 PM
Fabio D's Avatar
210 55
Replace both bulbs mate (left/right).. If you replace only one you got a different color. Xenon bulbs need to be replaced as a pair
Fabio Daniel
Old 05-21-2012, 02:52 PM
impalaman's Avatar
2000 E320 Wagon
Just found two bulbs on Amazon.com for $44 each. That's a good deal.
Old 05-25-2012, 01:48 PM
impalaman's Avatar
2000 E320 Wagon
Well, I replaced both of the the bulbs. My drivers side head lamp still did not work. I made sure the bulb worked by installing it on the other headlight. Looks like it is a bad ballast. I ordered a replacement universal ballast from here:
http://www.philipsxenon.com/philips-...ballast-p-1269
I'll let you know how it turns out.
Old 05-25-2012, 01:58 PM
impalaman's Avatar
2000 E320 Wagon
Correct!!! As long as you turn it like you've got a pair, it will come right off!
Just grab it like a man and turn it!
Old 06-20-2012, 07:27 PM
renault12ts's Avatar
W215 CL500 2005
Thanks.
Rotate counter clockwise...it needs a very firm twist. You shouldn't even have to loosen the three screws.
Old 06-20-2012, 07:30 PM
W215 CL500 2005
This happened to me. It turned out to be a bad earth (ground) to the lamp at that side. So I had to re-attach a bunch of brown wires.
Old 02-04-2015, 07:03 AM
e420power's Avatar
e420
sorry for bringing old thread, but im desperate searching for those yellow holders that holds xenon bulbs in place. Was changing the bulb and cracked that, stupid me. Any ideas where i could find that?
Old 02-04-2015, 08:27 AM
W215 CL500 2005
MB dealer?
Old 02-04-2015, 09:34 AM
e420power's Avatar
e420
Originally Posted by renault12ts
MB dealer?
"This part is not sold separately and it is not possible to oder" - Mb dealer
Old 02-06-2015, 09:34 AM
W215 CL500 2005
You have a problem then...it is not likely to be available anywhere else except in a scrap car.
Quick Reply: How to remove xenon headlight bulb??
