Seat Belt Tensioning at Start-up Toggle?
2014 E350 Wagon
I've had my e350 wagon for about a month and I've noticed that the seat belt is not tensioning as it once did at start-up. Does anyone know if I may have toggled a setting, or is this a sign of a problem?
There is a setting for it in the main instrument cluster I believe. Have you checked the setting to see if it is enabled still?
Yes, it's a setting that you can access (along with many other settings) on the multifunction screen inside the speedo.
If you're asking and I'm not sure you did, I turned off that belt tightening ridiculousness straight away. Absolutely bugged me.
Then I turned off the incessant horn beeping on lock / unlocking. Hated that, too.
I go back and forth on DRLs for no good reason.
I love buttons and options. I make changes for no good reason just because I can. Ha!
11' E-350 (P1 with SP-I guess-still a newbie).
2014 E350 Wagon
THANK YOU!!!! This forum is truly impressive! I've toggled it back to the auto tensioning setting.
Re: Lock beep, you can adjust this under the setting menu in the instrument cluster, under the vehicle option if I recall correctly.
Looks like I'm not the only one who has the beep oFf and can't decide on the DRL.
2014 E350 Wagon
I really need to read the manual again, every time I look through it, then toggle with the settings I find something new. This is one I haven't noticed yet (DRL's), regardless, it's great that you can modify so many settings. Nothing like being able to change something, only to change it back, I mean who doesn't like control?!
