R1 Concepts| Introducing R1 Concepts Forged Series Big Brake Kit!
Former Vendor of MBWorld
R1 Forged Series Big Brake Kit!
"Maximizing brake performance to the highest level!
R1 Forged Series Big Brake Kit is made for those seeking maximum performance in braking. R1 Forged Series Brake Rotors are manufactured with High Carbon (more Carbon, Chromium, and Molybdenum), the R1 Forged Series Brake Rotors offers increased braking performance and strength. A center split core castinf provides greater stability. Black Electro Coating protects against rust while extended rotor life. Mill balancing and double disc grinding reduces thickness variations for smoother stopping, minimal vibration and improved break-in.
*AVAILABLE IN DRILLED ONLY, SLOTTED ONLY, OR DRILLED & SLOTTED
Calipers
- Forged Aluminum 6061 T6
- Available in 4 piston, 6 piston, and 8 piston
- Available in paint or anodized in a variety of colors (both with clearcoat)
Rotor Hat
- Aluminum 6061 T6
- Black Hard Anodized (Standard)
- Available in a variety of anodized colors or Raw Finish
- 2 Piece (Standard)
- Floating (Upgrade)
Rotors Sizes
- 330mm (12.99") FRONT/REAR
- 345mm (13.58") FRONT/REAR
- 356mm (14.02") FRONT/REAR
- 365mm (14.37") REAR
- 380mm (14.96") FRONT/REAR
- 405mm (15.94") FRONT
Pistons
- Aluminum (Standard)
- Stainless Steel (Upgrade)
- Knockback Springs available (Upgrade)
*IF YOU HAVE ANY QUESTIONS OR ARE INTERESTED IN PURCHASING, PLEASE PM OR EMAIL KEVIN@R1CONCEPTS.COM*
