Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes-Benz E-Class: How to Replace Your Alternator
Step by step instructions for do-it-yourself repairs
How to change Voltage Regulator on the Alternator ?
In regards to my this thread https://mbworld.org/forums/c32-amg-c...ml#post3951913
Culprit-Voltage Regulator on the Alternator.
Can any one tell me how hard it is to change this voltage regulator ? My MB is charging me $821 to change the voltage regulator. Obviously I am not going to pay that, so please tell me how easy it is to change a voltage regulator on an alternator. Thank you in Advance.
e55
e55
also an old school test to do is start car and remove the negative side of battery and see if it shuts off if it does then its the alternator .. i have it go out a few times in my car so i test it like that now
I have exactly the Same Issue of light flickering
u have to raise the engine to get alternator out then on back side of alternator is the voltage regulator it's really a easy job sine i have had to take mine out 6 times . but if u have local place to rebuild alternator have it done . but raise engine and from underneath u have to take it out that way
NEVER do that !
if you don't want to put at risk all your electronics.
(old school cars weren't so plenty with them)
just start car, switch on lights and check with a tester: if voltage shows around 13.9Volts and above, means the Alt is charging fine.
Still looking for a lead on the Flickering issue
sorry for correcting but this cannot be left unedited
NEVER do that !
NEVER do that !
Still looking for a lead on the Light Flickering issue.......
2003 SL55, 1978 280SL, 2007 ML63
Thanks - Hope it works for me too
Sounds like the problem I was having: https://mbworld.org/forums/w211-amg/...ml#post4112363
