- Mercedes-Benz E-Class AMG: How to Replace Alternator
Step by step instructions for do-it-yourself repairs
Alternator advice please
What about an E350 alternator - is that not compatible? This is an example I have: http://cgi.ebay.com/ebaymotors/MERCE...Q5fAccessories
If neither is compatible, does anyone have a good source where I can get a replacement alternator and not pay the $800 from the dealer? I don't want used, but a remanufactured one with at least a 3-month warranty is fine - or even a used one with a 12/24 month warranty. As long as it provides enough current and is a direct replacement, I don't really care who makes it. Thanks for the input.
Did you try to price having yours rebuilt? EPC shows it in parts so it should be able to be rebuilt.
How do you know the alternator is dead?
How have you ruled out a bad voltage regulator/brush set?
It is easy to change.
90% of the time a new regulator solves charging problems.
Here is a good read.
http://www.humanspeakers.com/audi/alternator.htm
A new alternator is (a real new Bosch) dealer net is $600.
Your choice, I would go the new regulator route cause you can change it out in 10 minutes while the alternator is in the car.
The Bosch Alternator is of the highest quality and will last 20 years 250,000 miles the voltage regulator on the other hand only lasts 60-80,000 miles, the reason is that the regulator also houses the brushes that are a wear item.
Here is information on battery controls that are not in the alternator.
http://www.mercedestechstore.com/pdf...2011-29-02.pdf
I ended up buying it from here: http://www.aboveallmotorwerks.com/pr...n=013154850288, shipping was pretty quick.
The battery was testing ok but I knew it was just not charging properly and sure enough new battery fixed everything because it was being overworked by the ****ty voltage regulator in the alternator.
By the way it appears my car already had the alternator repaired under warranty in 2006 so this was the second issue.
Last edited by NORCAL///AMG; Jun 23, 2010 at 03:58 PM. Reason: found part number and more info
Make sure your new battery is vented to out side of the spare tire well, the gas produced by battery is explosive.
