Sythetic Oil
Reality:
Mobil 1 does not cause leaks. In fact, Mobil 1 was tested in dozens of industry-standard and OEM tests to prove its performance. It is fully compatible with the elastomeric seals and gaskets used in virtually all modern engines.
When the first Mobil 1 was introduced 30 years ago during the energy crisis, it was a very low viscosity grade (5W-20) that was optimized for fuel economy. At that time, engines were designed for much heavier grades of oil (e.g., 10W-40) and tolerances were much “looser” than in today’s engines. Sometimes, the original Mobil 1 formula used in an older engine would actually clean out the sludge build-up that was keeping the oil from leaking. Engine designs produced since the mid-1970s are made with tighter tolerances and better seals, and the phenomenon has disappeared.
Likewise, in an older engine in good condition – one that does not have oil leaks or one that has been rebuilt properly using new oil seals – Mobil 1 provides the same advantages as when used in a new engine. If an older engine has an oil leak, ExxonMobil recommends repairing the leak, then using Mobil 1.
When I was waiting at a franchise oil changer, a customer ordered synthetic for his Focus. When the manager found out, he ordered it to be drained and filled with regular oil. He just said that it should not be done, as if it were a serious specification, but did not say why. It might have been an '08 Focus.
I would have gone to a different shop too.
