Best oil for older 190?
One other question to toss out for 190 drivers...
My 1991 has 212K miles and have been running the Valvoline High Mileage oil over the past several years...changed at 2K intervals.
Any favoritie oil for high time MB 190s?
It depends on your climate, refer to the owners manual for recommend oils for ambient temps.
I recently placed Conventional Valvoline 20W50, SoCal never gets below 32F unless you are up in the local mountains skiing. No worries not going to go up there in here any time soon.
Take care not to go to thin or synthetic, you may develop leaks.
Heck I run 20W50 VR1 in my 911
Best Oil...thanks for the tip
Hi Draco...here in frosty ( and it is today!) Ohio the temps always seem to be around 32 and lower!
Im going with a Valvoline High Mileage 5 - 30 W as I want to get the oil up the cam tower to keep the top end nice and lubed...
In a perfect world I would fit a pre-oiler to the engine just like we have on our CAF museum P-51 Mustang; turn it on and run the oil thru for a few mins...
190e
190e
I found this information after a quick google search.
Mixing Mineral and Synthetic oils - current thinking
Here's the current thinking on the subject of mixing mineral and synthetic oils. This information is based on the answer to a technical question posed on the Shell Oil website.
There is no scientific data to support the idea that mixing mineral and synthetic oils will damage your engine. When switching from a mineral oil to a synthetic, or vice versa, you will potentially leave a small amount of residual oil in the engine. That's perfectly okay because synthetic oil and mineral-based motor oil are, for the most part, compatible with each other. (The exception is pure synthetics. Polyglycols don't mix with normal mineral oils.)
There is also no problem with switching back and forth between synthetic and mineral based oils. In fact, people who are "in the know" and who operate engines in areas where temperature fluctuations can be especially extreme, switch from mineral oil to synthetic oil for the colder months. They then switch back to mineral oil during the warmer months.
There was a time, years ago, when switching between synthetic oils and mineral oils was not recommended if you had used one product or the other for a long period of time. People experienced problems with seals leaking and high oil consumption but changes in additive chemistry and seal material have taken care of those issues. And that's an important caveat. New seal technology is great, but if you're still driving around in a car from the 80's with its original seals, then this argument becomes a bit of a moot point - your seals are still going to be subject to the old leakage problems no matter what newfangled additives the oil companies are putting in their products.
Read more: http://www.carbibles.com/engineoil_b...#ixzz1eLtmQdTK
And to answer the OPs original question, based on what I've read at www.bobistheoilguy.com, it really doesn't make much of a difference what brand of oil you use but sticking with the big name manufacturers is generally the safest bet. I personally run Chevron oil and have not had any problems.
Well, try what ever you want, it is your car do what you will with her.
In my experience, on my '85 911, I went from a partial synthetic 20w50 to conventional high zinc 20w50, leaks stopped. On my 96 Lexus, went from recommend 5w30 full synthetic to 10w30 Toyota Conventional, leaks stopped.
Maybe I am just lucky
Thanks all!
Just went with Valvoline Max Life 5-30 for the cold Ohio weather...
Also had the rear flex plate changed out....drives like a dream!
Thanks to all MBworld posters!
2002 CLK55, 1993 190E, 1975 230C, 2007 E350
Group III or IV
Tribology is best left to those who delve in it deeply - I work with some of them, and they all run Group IV oils in all their cars. I follow their advice -- my daughter's car just got changed over to Mobil 1 0W-40 for winter in Minnesota, and my CLK55 and E350 both run it year round. Ran it in my old E320 for 10 years with no problems - daughter learned to drive in that car, miss it very much.
