LED Dash Lights
Not a single one of my dash lights, switch lights etc are burnt out so far. I was also worried about the exact same thing but the data is there. I would not replace the bulbs thinking they are going to burn out. Also the led's you replace them with, can you trust their life? Where are they made? I may not have told you that I worked in the LED lighting industry in the early days and I have seen it all.
I am surprised these tungsten dash light bulbs can last this long but then again, it is not that many hours. For my car probably maybe 8K-10K running hours and if it is 20% with lights on we are at 2K hours.
I could be off by as much as 2x here. This is the general life of a good quality tungsten bulb, so you would expect them to start failing. But why are they not?
My guess is that the bulbs in the car operate at very low power rating compared to their build. They do not even get that hot as you know for good reasons. Not like home lighting anyway.
And of course we have heard of 100+ year old Edison bulbs still working because they may have been over designed/under powered.
There is another issue with LED bulbs in automotive or home lighting, if the hue/color does not match each other they look awful. So it is an all or nothing approach. And you will need 2300K or 2700K LED bulb for all of them. Will you be able to find them in all different form factors?
Also remember LED bubs are unidirectional and inserted the wrong way could blow fuses (particularly the one you are replacing) if not inserted correctly. Not sure if they all have current limiting resistors to avoid blowing of fuses.
For me I have replaced the dome light (rear and front) glove box light, license plate, all brake lights, parking lights, including European city lights with LED's. Those are the one that matter for power consumption. And now there is more light coming out of those lights as well as 1/10th the power consumption. Also these bulbs are easy to replace if needed unlike the dash bulbs.
For your car, I would not even consider replacing the dash bulbs. But if you decide to, make sure you get them from a reputable place like superbrightleds.com. I have replaced all my landscape lights from there (and for the W201 ones I mentioned) about 10 years ago. Not a single one has failed so far. And these guys unlike the auto stores have the period correct coloring, not the 5K or 6K rubbish that looks very blue in a W201. Those will certainly clash with the new Continentlal Radio you just put in.
Here is an example, you have seen the EHA and Voltmeter gauge I put in. Originally I had a 2700K LED bulb in them. They looked awful and did not match the rest of the lighting even at 2700K.
I had to replace them with an "orange" LED, and now the match is near perfect. So it takes some experimentation as you see.
My 2 cents worth.
Cheers and Happy Holidays!
One more issue with LED's that members who have done this should respond to. I wonder how well the rheostat/dimmer works with LED's. I suspect not very well.
- Cheers!
I sometimes turn on my parking lights to benefit from the city light feature but that does not turn on the dash light as far as I recall.
My grandson tells me he is going to join the forum so he can pose his own questions.
Cheers!
Weather patterns have certainly been strange lately. Never heard of a tornedo in December either....
As for me, for the first time ever that I recall my car is having a harder time to start near 40F weather. It starts, but struggles for the first 30 seconds. Before, one quick strike and it would just start in a fraction of a second and hit 1000+ rpm right away. I will have to look at the usual suspects. Most likely the cold start valve is not firing as it should. Fortunately, I have the EHA gauge in the console so I know it is not related to fuel enrichment. Maybe that gauge is paying off already....
