190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Noise when turning steering wheel from under car.
Old Jul 13, 2023 | 05:00 PM
LauraS's Avatar
1990 Mercedes 190E
My grandson showed up for a visit with his 190E and he reported that the car was making a loud clunk noise when the steering wheel was turned either way. I test drove the car and the sound can be not only heard but there is a slight binding in the steering and the power steering seems to be not working well. I suspect that the steering u-joint may be sticking since it seems to bind and then loosen as the wheels are turned in either direction. Is this a difficult part to change if this is the problem? I recall years ago our old Ford F150 had a similar problem and my late husband said the joint needed lubrication. Some oil solved the problem. This seems to be a very similar situation and I am hopeful that the joint needs lubrication but haven't tried it yet.
Old Jul 14, 2023 | 03:27 AM
dolucasi's Avatar
190E 2.6L 1989, 190E 2.6L 1988, BMW 535dXdrive 2014, BMW 428i 2015
Sorry to hear. Not usual with the steering part going bad like that. Make sure the simplest thing is not the problem. That would be the dampener. Maybe it is freezing up?
Normally when old they do the opposite though, they loose their shock absorption and do not do anything. You can temporarily undo it to see if the problem goes away.
While out you can test it for operability.
- Cheers!
Old Jul 14, 2023 | 08:40 AM
LauraS's Avatar
1990 Mercedes 190E
Thank you. We will look into it today and report back. It certainly is binding the steering somewhere.
Old Jul 14, 2023 | 04:12 PM
LauraS's Avatar
1990 Mercedes 190E
Well thanak goodness the noise seems to be from the driver's side strut bearing. With me slowly turning the steering wheel and the grandson under the car (hydraulic floor jack and 6 ton jackstands supporting the vehicle) he was able to isolate the noise to the strut mount. I shot some WD-40 over top and around the bearing and the noise is gone! Too bad we spent all that time removing the splash pan. I guess a new strut mount is on order. It looks like a not too difficult job. Do these mounts hold a bearing or was the noise just from lack of lubrication? Thanks for the help.
Old Jul 14, 2023 | 10:09 PM
dolucasi's Avatar
Is this the part of the strut that connects the strut to the hub Laura? Is it part of the strut or part of the hub?
Old Jul 14, 2023 | 11:30 PM
LauraS's Avatar
1990 Mercedes 190E
Dolucasi, The part that was making the noise was the strut mount, the part that holds the shaft of the strut to the vehicle body.
Old Jul 15, 2023 | 12:56 PM
dolucasi's Avatar
Oh , I see you meant the strut mount. If it is squeaking likely the rubber is cracked and or the strut tower clamp is rotating. Is the clamp staying put?
If originals most likely you will need it replaced. One of mine went bad maybe 10 years ago. I replaced the set about 5 years ago. Super easy.
Old Jul 15, 2023 | 01:37 PM
LauraS's Avatar
1990 Mercedes 190E
I did mention the part as the strut mount in my previous post. The mount didn't squeek but rather clunked intermittently when the steering wheel was turned. By strut tower clamp do you men the metal bar under the top nut? It doesn't rotate or move as wheel is turned. I will order a set and install although for now the WD-40 seems to have smoothed out the steering with no noise.
Old Jul 15, 2023 | 01:51 PM
190Efan's Avatar
1991 190E 2.3
Unfortunately, the WD-40 might turn out to be a temporary fix. I realize that you do have new mounts on order which is good. You might also want to check how the tires are wearing. Tire ware can provide additional clues as to what might be happening that could point to the need to replace additional parts in the suspension and or steering.
Old Jul 15, 2023 | 02:04 PM
dolucasi's Avatar
Sure sounds like the mount is compromised somehow. Perhaps it is torn internally and it does not show. Best to replace like you are doing now.
- Cheers!
Old Jul 15, 2023 | 04:23 PM
LauraS's Avatar
1990 Mercedes 190E
190Efan, Thanks for the advice. Tire wear seems to be normal and the car handles well at highway speeds so I am confident everything else is OK. I will have the grandson take to the garage I deal with when I am in town (100miles away for me). Dealer is 450 miles away and I don't often get that far from home anymore.
Old Jul 15, 2023 | 04:26 PM
LauraS's Avatar
1990 Mercedes 190E
- Cheers!
Parts will be on the way soon. I will change both sides.
Old Jul 17, 2023 | 12:09 AM
190Efan's Avatar
1991 190E 2.3
Glad your tire wear and handling are normal. That further implicates the mount as the culprit. I think Dolucassi may be correct that it's an internal issue with the mount. It's always wise to replace such mounts in pairs.
Old Jul 17, 2023 | 12:46 PM
LauraS's Avatar
1990 Mercedes 190E
Thanks, will change both.
Old Jul 28, 2023 | 03:37 PM
LauraS's Avatar
1990 Mercedes 190E
New strut mounts arrived and the noisy one was repalced. It seems to have been the problem since no complaints from the grandson since he drove home. I have the other one in the box ready to install when the opportunity arises. Strut mount was $65 locally and $22 each from Rockauto + $22 shipping for both. Sachs brand so probably a good part.
The removal and install took about 1 hour.
Old Jul 28, 2023 | 04:30 PM
dolucasi's Avatar
Super Laura! Glad it was the simplest of fixes.
