Tank/Fuel Pump/Filter removal
randy
In my experience (I've had German cars since the 90's) very few parts can be omitted without there being a consequence.
Greg
But can you explain this:
RandyMorgan>>> My local dealer does not have it, but offers one through a third party for $100
Dealers will only sell parts in their supply chain not 3rd party. So I'm confused about this set-up but buying it thru the dealership is always a better option.
Any suggestions for help will be appreciated.
First secure the strainer, no cement needed the gas will just erode it away eventually, It does have to be super tight but once you feel like it’s going to break stop immediately. My original was almost impossible to remove but I ended up with new tank and left it alone….
With the tank and strainer in the car, I crawled underneath to align the main outlet line might be easier if the tank is not bolted in, you can try holding the strainer in place with channel locks as you screw in the main outlet fuel line with another wrench.
once you stop all the leaks it should run, system is gravity fed so a disruption in flow seems capable of causing a stall in my experience
The seal is the oring, once the metal surfaces mate, tightening further will not get you anywhere but perhaps stripped threads.
Take it apart and do it over and do not use gaskets, seal compounds etc.
I mentioned this before in this thread, when I cleaned out my fuel sender I had a heck of a time to avoid leakage with a full tank. I had to lightly sand the sender and tank side surface to achieve a smooth finish. Once that was done no leaks. The sender and the strainer is the exact same joint. When I installed a new fuel strainer I lightly sanded the tank to remove crud.
No leaks in first try.
On the stall during idle, that is most likely a completely separate issue and needs to be diagnosed later once you have a leak free installation.
Again you guys are a great help to me and I am most appreciative in your time and effort responding to me and trying to help me get this old 190 back on the road
i actually recall now I did fit the line to the strainer before putting the tank in the car, that’s how I broke the vent valve so be careful with that too. One line is a vent valve the other is a fuel return I believe, don’t mix them up
When I replaced my strainer that was in there for 35 years that large nut was not tight at all. Factory installed in '89. I was surprised too, but soon realized there is an o-ring there. I have also removed that fitting on a few W201's in the junk hard. All the same.
Simply put: tightening that large not will not get you anywhere, except into trouble. Once the two metals meet and hand tight, you are done.
Just consider all those coolant lines with o rings and strong pressure. At the pump, return line, at the cylinder head, heater core, etc, etc. All are torqued just so they stay put, not to avoid leaks upon installation.
Just make sure that the leak is from the o-ring and not the newly manufactured fixture.
And then make sure the surface is nice and clean on the tank side and you have a properly sized 0-ring. I always slightly grease an o-ring with silicon to make sure it does not get damaged during installation.
Trust me on this one.....
When I was at the point you are, I also used the starter fluid to get the motor to start and then once it seems like it’s going to run , hit and hold the gas pedal lightly until the motor catches and see if it starts running on its own. You will need a second person you can trust to not overspray the starter fluid and not fully floor the pedal. There could be slight condensation or debris in the injectors. I did replace my injectors with the gold ones but at this stage it wasn’t really a factor
If that doesn’t work you will need to check spark/voltage and air (vacuum leaks)
You are not getting fuel into the cylinder by means of the FD. It is only getting fuel form the cold start valve which allows it to run for a second or so.
Since you had all the plumbing open for months on end it is possible that the system has dried out and void of any fuel.
When this happens, it takes many many starts to get the fuel the flow.
To verify this, remove one injector and stick it in a nylon bag or jar. Crank away and see it is is spraying any fuel. My guess is it is not.
randy
randy
The accumulator would not cause a no-start, only simply a hard to start, or a slow re-start. It's just there to maintain pressure so you have quick engine starting.
Has the ball that blocks off adjustment of the mixture screw on the fuel distributor been broken to give you access to it? Or is it still "factory settings"
Injectors are cheap enough that they are worth replacing, if you look at the "kit" FCP Euro has, order everything except the really expensive sleeves. I would also recommend replacing your two idle control valve hoses, buy them from the dealership to get matching genuine Mercedes ones. I wouldn't buy the non genuine ones, since the genuines are cheaper.
The main fuel tank line is a 14mm ID hose. I have some left over from refurbishing my car. It's good Cohline stuff, proper. If you want some, let me know. Mine was totally collapsed from sitting so nothing would come out.
I would push down the on the AFM disc slightly while a helper turn the key to start the car. If the vacuum of the engine isn't great enough to pull down the AFM disc that pushes the piston of the Fuel distributor to get the fuel and fuel pressure to the injectors. The culprit would be a massive air leak past the throttle body. ICV hoses, AFM boot cracked, etc. There is an adjustment procedure that coordinates the position of the FD piston and AFM disc.
There is also a filter at the inlet of the FD that needs cleaned.
I could not working on these cars without a set of Fuel pressure .gauges. Without the Fuel pressures in spec and volume flow these cars won't run. So I'm thinking the PO messed with the 3 mm screw to 'tune' the car.
Let us known.
I will check the filter that you mention before I replace the injectors. If I do replace the injectors do I need the seal too, and the O ring? It seems that FCP Euro has the injectors, but not the seal, and AUTOHAUS AZ has the same injectors and as well the seal.
