Curb weight of 190e
if the European models truly are materially lighter than the US versions, what was the reason for this?
gosh -350-450 lbs seems a lot for a sunroof and power seats?
- Cheers!
At 6’5 there will be no Asian cars. I already have a Porsche but honestly its too nice to track and consumables are high. The logical choice is an e30 or e36, but the former is getting old and doesn't have great suspension - the latter has lots of aftermarket, but they have become pricey and hard to find a good example as they have succumbed to becoming clapped out drift cars in many cases. Both of those cars now have a multitude of Honda k24 engine swap kits.The reason these cars are so popular is they are light weight (relative to late model cars) and they are rwd.
The 190e is similar to these cars as it has the same characteristics noted above. They are relatively cheap, plentiful and in much better condition than the average e30/36 at this point. The only drawback is there wasnt as much depth to the aftermarket performance but I was surprised how much is available. That and Honda kswap kits are coming….
For me Im 50 years old and just looking to build a lightweight lapping car that I can drive on the road. I will have a/c, full cats/muffler exhaust but will probably gut the rear seat and other weight reduction. Think “clubsport”.
The car below is a kswap example - weighs around 2700lbs without driver as the honda engine and bmw zf320 manual trans is much lighter than stock stuff. Has the rest of the full MB interior. A fun lapper now.
https://www.mattcaudell.com/k24-swapped-mercedes-190e/
But that will not give you the big project you are looking for.
Nobody leaves them stock either. 50 deg vtc and a tune and you are at 250 hp crank. Add cams and you are at 300hp. Guys turbo the stock block and are at 350-400. On top of it its just a good reliable motor. Added bonus is its all aluminum so its light and sits behind the strut towers in most cars. The engine mentioned above is iron block and probably has little aftermarket.
Its a car. Not a religion. I don't want a front wheel drive Honda I want a MB 190e that is not the slowest thing on the road, hard to gets part for, impossible to tune, and gets bad MPG. Also that "ordinary Honda engine" is a bout a million time better engineered than the m102 m103 CIS is the worst.
