AMG GT: GT, GTS, GTC, GTR, GT-4 door (C192 / R192) 2024 - present: The GT/GT S is the second generation GT sports car developed entirely in-house by Mercedes-AMG.
GT/C192/R192: Questions about Front Axle Lift option
Old Oct 28, 2024 | 10:51 AM
LAZARU5's Avatar
2025 E53 Hybrid
I am considering getting a 2024 or 2025 AMG GT55. I am certain that I need the Front Axle Lift option to comfortably enter and exit my driveway. Can the front be raised from a steering wheel control, or is this feature operated from selections on the console screen? What are the approach angles for the AMG GT55 in both the normal and raised positions. My estimate of the angle in the normal position is < 10 degrees.
Old Oct 28, 2024 | 02:05 PM
Rebelwon's Avatar
2024 GT 55
Pretty sure the front axle lift can only be accessed by the central display; however, you can program it to remember locations needing the lift by GPS (see p. 224 of the owner's manual). Lift is, IIRC, about 1.2 inches. Sorry, but i don't know the approach angles.
Old Oct 28, 2024 | 04:32 PM
LAZARU5's Avatar
2025 E53 Hybrid
Do you think the 1.2" (30mm) is measured at the axle or at the most forward low point under the car? If the latter, then the lift at the forward point could be as much as 1.5".
Old Oct 29, 2024 | 07:55 AM
Rebelwon's Avatar
2024 GT 55
Not sure, but would expect it is from the axle.
Old Oct 29, 2024 | 08:57 AM
philenan78's Avatar
2025 AMG GT55, 2023 AMG SL43, 2023 GLS 450
You can add the front axle lift as an option on the left steering wheel dial, which is what I did. Doesn't come standard like that, but easy to customize from the main console screeen.
Old Oct 29, 2024 | 11:03 AM
LAZARU5's Avatar
2025 E53 Hybrid
Are you saying that the steering wheel option to activate the Front Axle Lift is a separate option from the FAL itself? Or is the steering wheel "switch" automatically included when you select FAL?
Old Oct 29, 2024 | 12:14 PM
philenan78's Avatar
It's not a separate option. If you option the front axle lift, the default way to activate it is through the center console screen. However the left steering wheel knob can be customized to include almost any function, so the front axle lift can easily be added as an alternative to that knob. Once it's added as an alternative then you can control the lift system through the steering wheel by cycling through the options and clicking the lever to activate/deactivate the lift function. Hopefully that's clear.
Old Oct 29, 2024 | 12:15 PM
LAZARU5's Avatar
2025 E53 Hybrid
Thank you for the detailed explanation.
Old Nov 5, 2024 | 02:09 PM
LAZARU5's Avatar
2025 E53 Hybrid
Stopped by my local dealer this week and requested a demonstration of the Front Axle Lift option on an AMG GT55.
I took a few measurements with the Active Aerodynamics Profile (AAP) retracted. At normal ride height, 660mm ahead of the front tire patch, the ground clearance is about 100mm at the scalloped outer edges of the APP. With Front Axle Lift engaged the clearance increases to about 140mm. The outer edges of the AAP are flexible and can be pushed upwards over 20mm. The ground clearance at the center of the AAP is about 163mm when the front axle is raised.
These three ground clearance measurements, 100mm, 140mm, and 163mm correspond to approximate approach angles of 9, 12, and 14 degrees. Repeatedly scraping the outer edges of the AAP on driveways with greater than a 12 degree slope is probably not a best practice.
Only a small portion of the C192 AMG GTs appear to be equipped with the Front Axle Lift option. it would be interesting to hear about ground clearance challenges from some forum member without FAL. With the AAP extended, I believe the approach angle decreases to about 6 or 7 degrees which might make it difficult to clear road kill at speeds above 50 mph.
Old Jan 16, 2025 | 10:11 AM
prodigymb's Avatar
997TT, C192 GT63, W464 G550, MS Plaid
programming FAL to the left steering wheel quick access button is the move. that is how i have it on my GT63
Old Jan 17, 2025 | 06:39 AM
racingmd's Avatar
2025 AMG GT 55; 2022 e53 coupe: 2019 e450 coupe
Can you post a picture of the FAL on the steering wheel? The only option I have there is for raising or lowering the front splitter.
Old Jan 17, 2025 | 08:57 AM
philenan78's Avatar
It's not one of the default options, you need to add it through the customization menu in the center console.
Old Jan 17, 2025 | 09:14 AM
racingmd's Avatar
Thank you! I will check that out today
Old Jan 29, 2026 | 02:36 PM
LAZARU5's Avatar
2025 E53 Hybrid
Does the symbol circled in red in the attached photo indicate that the GT55 includes the Front Axle Lift option? If not, which icon is used for the FAL option?
Is this the Front Axle Lift feature?
Old Jan 29, 2026 | 03:34 PM
ffejnotrom's Avatar
2019 G63 AMG & 2024 AMG GT63
No, this is the front aero under the front bumper. Front axle lift icon will show an entire little car on the button, with an arrow pointing UP only.
Old Jan 29, 2026 | 08:32 PM
ffejnotrom's Avatar
This is what the front axle lift icon looks like:
Old Feb 4, 2026 | 11:56 PM
mgeddes's Avatar
2014 MB G550
philenan78, you are awesome. That was a pet-peeve having to go through the center screen. Added the massage seats there as well. Thank you!!
