GT/C192/R192: Option to disable the speaker generated engine sound in the AMG GT 55 ?
When I test drove the AMG GT 55, it sounded a bit weird and artificial in Sport/Sport+. The AMG V8 has a great natural sound, is it possible to enjoy the real exhaust and turn off the artificial one from the speakers ?
After an OTA it may be enable back, but can be coded again and again with a 15$ interface and a decent Windows 11 laptop.
for MBUX 2/3 , this seems to be the method to enter this mode :
There is another video that shows the AMG sound volume can be changed in the audio volume menu.
for MBUX 2/3 , this seems to be the method to enter this mode : https://www.youtube.com/shorts/Tc-C65bPqnA
So I either did something wrong, or this section is not how you turn that off.
I would love to know as well because I find it quite annoying and much too artificial sounding. would prefer the normal standard exhaust.
AMGRACEAPP may be related to the AMG track app, not the AMG sound.
In the the other video I saw , it was under dealer mode -> Audio Volume -> "AMG volume " (or something like that, I don't remember the exact name)
I hit the assistance 10x times, it pulled up dealer menu (picture 1)
hit Audio volume, and it opens the next menu where it shows the comfortvolumeactivationstate (picture 2)
then then select one of those and it shows the last menu which lets you toggle all those on and off (picture 3)
the comfortvolume min and max if you press on them you can adjust the level and decibels which I tried.
It seemed to be the same no matter what. So i'm not sure if that menu is where the engine noise can be turned off or not, and if it is, I don't know where it is located, or what tab it is, because AMGRACEAPP is not it. at least if that is it, it didn't seem to do much when I played with it.
And did you also go in damping ?
(with the older MBUX :
There is another video that I cannot find where the driver also configured the audio in damping, in addition to volume min and max.
i did slide the amgraceapp thing all the way to the left and it didn’t seem to change anything.
but it’s very possible I didn’t save the setting or didn’t do something else right. So if someone able to figure out how to turn this **** off , I’ll send them a cookie.
And with the Individual settings, is it possible to replicate Sport+ but without the artificial sound / louder exhaust ?
But that was my hope also was that I could set it up in the individual setting, but you cant, at least not that i'm aware of. I know that can be done in some other amg cars, but doesn't look like the GT you have that option.
