GT/C192/R192: GT63 Coupe- cabin engine/exhaust notes real?
Side question - those who have or do not have the front axle lift....do you use it? It is necessary in your opinion? The one at the dealer had it, but again the sales guy didnt know how to activate it. I guess I need to do my own due diligence and then go back to re-test drive.
Thanks for any feedback.
I would imagine to fully disable it, it would need to be coded that way. But thats above my pay grade.
I don't personally care for it, but it's not the end of the world also.
So as of now, to my knowledge there is no way to turn if off, unless there is an aftermarket coding option to have it done.
I'll need to have mine repaired also.... ****.
The part was not readily available at the PDC because its rare and they flew it in from Germany.
Edit- I think it was around 700.00 for the part
It's just a piece of rubber. I got under and had to take a razor blade and cut it off the rest of the way.
Funny thing is I dont even think it was from a specific scrape when it was down. I actually think it happened from even when its up, and there was slight scrape like on a rounded curb or something. Like it almost grinds the rubber away until it kind of broke free on one side. The mechanical piece that extends wasnt effected and looks fine. I just need to un screw the screws and put a new rubber flap on. Looks relatively easy to do. But also looks very easy that it will happen again.
Maybe not a great design by MB with how low the front is, and i'm not even lowered like you are. But I do have FAL.
Problem with front axle lift is, it's great, if you know, and can prepare with enough time for it to slowly lift, but its the areas you dont expect or dont have enough time to raise it. Oh well. I imagine this rubber will be a very very common piece that people need to replace. Seems a little too easy to rip it off accidentally.
*** edit*** Vic you wouldn't happen to have that part # handy do you? All the online part sources dont show it, at least where I can see it, and have a feeling I'll want to rip my ears off at a dealership. Would prefer to just order online and put it on, looks like a very simple repair.
it doesn’t appear that replacing it would be very labor intensive, but I haven’t messed with it yet. So I’m not sure if I’ll do it or just have dealer do it.
I got mine fixed for free but would still do it for several reasons; the results of the spoiler at higher speeds and I dont want to ever sell the car or trade it in without all the items on the car functioning.
It's able to be manually lifted and lowered also. So I doubt the car would raise up in the air if the rubber ripped, but I suppose it's possible at high speed cornering to lose a little stability. But I did not notice anything too worrisome while normal/spirited driving.
At any rate.... I was able to pick one up at my local dealer they had them in stock, not sure if the same part is on any other cars, but it was about $400.00 from my dealer. They wanted $300.00 to install, which is absurd. It was maybe 10-12 plastic plug/clips, and 2x 8mm bolts.
Took me longer to find my jack and get the car in the air than it did to replace. Very easy, and only need an 8mm socket/wrench and something to pop the clips out. the clips go back in by hand.
Really really easy, and no way I would pay more than about $25.00 to have someone install it. New part comes with a new plastic bracket that holds it in place.
Photo shows a few of the clips, they go all the way around. Kind of cool it appears the flap that gets pushed down may be carbon fiber but was hard for me to tell as I didnt get fully under the car. But in the photo the rubber was already cut off and not put back on yet, with it on youll see the rubber piece covering the front end of the carbon fiber flap.
Here is the part # which may be nice to keep in handy, for some reason all the online parts sites for some reason it's impossible to find. But here it is :
