Gt63 2019 possible motor blown
Old Jul 22, 2025 | 03:02 PM
Skytoproofing's Avatar
2017 c43 amg
I have a 2019 gt63.. was driving home and then all of a sudden had reduced power.. check engine light blinking. Sent it in to dealer and service advisor said is was cylinder 5 misfire, mechanice testing compression & leak down test.. couple days later I check in for an update and not really any further information.. service advisor claims its not good and might need a new motor.. they are waiting for next steps from mercedes..
Has anyone been through this issue surely it cant be the whole motor that needs to be replaced?!
Old Jul 22, 2025 | 10:31 PM
W205C43PFL's Avatar
The M177 (?) has an issue of leaking injectors but does not affect all of them was it specific batch, very strange that the engine just gave up like this? What was the oil temperature, coolant temperature, RPMs, etc. when this happened?
Old Jul 23, 2025 | 09:30 PM
2017 c43 amg
I was in comfort mode going about 80kms everything was normal.. I mean it was a very hot day out but other then that nothing out the ordinary I also wasn't driving in manual mode
Old Jul 24, 2025 | 03:40 AM
W205C43PFL's Avatar
Ugh yes what you experienced is rare on this engine sorry to hear about this experience
Old Aug 27, 2025 | 06:16 PM
sambam2006's Avatar
GLC Coupe, S63L W222
I had this same issue once on my CLS 63, I was told engine gone, changed everything possible engine related. And turned out to just be a shot o2 sensor.
Old Aug 27, 2025 | 06:37 PM
W205C43PFL's Avatar
Those pesky sensors.
Old Oct 9, 2025 | 08:21 PM
GT63Sfrank's Avatar
AMG GT63S
and then?
What is the update? This sounded like you had multiple coil failures not just one of the 4. Maybe 2 at the same time or complete failure of one affecting 2 cylinders.
Old Oct 9, 2025 | 09:10 PM
2017 c43 amg
UPDATE: so not a blown motor. Benz dug deeper, and found cams were caked with soot. They tried to clean it and confirmed all was good. I had it for less then 24 hrs and then same issue. Sent it back and they cleaned it again. So far so good.. shop foreman recommends to change oil separators
Old Oct 9, 2025 | 09:53 PM
PeterUbers's Avatar
join the not so exclusive club! Add yours to the database
https://mbworld.org/forums/w213-amg/...fail-club.html
