Sponsored by: Innova
Hacking Command 2.0
Old Sep 16, 2005 | 11:33 PM
epirian's Avatar
2003 MB CLK 320 (W209)
Post Hacking Command 2.0
Hello,
I have a 2003 clk 320(w209) with the command navi. I was wondering if the back of the command system has a VIDEO input... Is there a way of hacking it so I can watch tv dvd and play playstation games? Thanks!
Old Sep 17, 2005 | 03:36 AM
benzmodz's Avatar
W203 slightly modified
Originally Posted by epirian
Hello,
Sure. You can buy a medium quality adapter from eBay and just plug in the bits at each end.
Search eBay for "mercedes tv" and you will get all kinds of sale items.
Old Sep 17, 2005 | 11:26 PM
Blake P's Avatar
'09 A4 S Line
...or you can email steve@mbenznl.com and he will sell and install an adapter, as well as activating the blank button on your Comand to show video in motion! This is assuming that you live in a location where he visits since you did not bother typing in a location when you set up your profile.
Old Sep 20, 2005 | 02:12 AM
kaiju's Avatar
2010 ML350 CDI AMG Sports, BMW e92 335i (sold), CLK240 Avantgarde (sold)
Hello,
only option is to get a Merc TV tuner or Dietz Adaptor.
Cheers.
Old Sep 21, 2005 | 01:11 PM
captret's Avatar
2006 E320 CDI.SOLD..'02 CLK430 Cabrio(SOLD),08 Disco3..1996 FLH-TP, 2017 E300
Cheers.
"K".....May I ask where you purchased your Dietz adaptor. I found a place on ebay, but they'll only accept funds thru a bank transfer.
BTW....SteveNL's adaptor only accepts a PAL signal, which is fine for most DVD players, but not for a USA TV signal (NTSC).
Old Sep 21, 2005 | 07:10 PM
kaiju's Avatar
can't remember the exact shop but it was also from ebay... ebay.de that is. But I think the video system will be the same, it will only accept Pal as well. You maybe better off getting a Merc TV tuner if you want to use it for TV... the Dietz Adaptor is only for for those who don't want the TV Tuner.
Cheers.
Old Nov 1, 2005 | 03:59 PM
captret's Avatar
Dietz works
FYI, RE: Euro COMAND 2.0 W208 w/ Blaupunkt DVD-ME3 (Built-in TV tuner)
Finally bought a Dietz 1440 RGB converter on Ebay from Caraudio24, (they finally accept PayPal).
It takes a little work to hook it up correctly, for example, the VSS wires, CD changer and Aux input, have to be wired into their C1 & C2 connectors.
I just used SteveNL's harness and swapped out his converter (PAL only) with the Dietz 1440 by switching the pins between the two units.
Result.....I used to have to set the DVD player to the PAL mode to watch DVDs (worked fine).....but had no TV (picture tore & rolled). Now, with the Dietz I can set the DVD Player to NTSC mode and get a watchable TV picture. (The tuner and antenna on the Blaupunkt are marginal at best). I can now also use the A/V inputs on the Blaupunkt for cameras, games etc. and get a good picture on the COMAND.
A cheapo way out if you can't get an original MBenz TV tuner.
Old Nov 1, 2005 | 05:00 PM
superflysocal's Avatar
so without steve's harness, how much work would you say is required...is it not plug and play? I too have a w208 with uS cd comand.
Old Nov 1, 2005 | 08:52 PM
captret's Avatar
Easier w/ COMAND already installed.
IMO......Not difficult at all, just switch the pins from the Dietz converter into your C1 & C2 connectors, (actually, that is what Dietz states in it's instructions).
Old Nov 2, 2005 | 03:03 AM
linuxfoo's Avatar
hi captret,
would you happen to have your wiring diagram for your Dietz adatpater? and also do you still happen to have your old PAL (steve's ) adatpatyer laying around you might want to get rid of? thanks
Old Nov 2, 2005 | 09:08 AM
excuse my ignorance, but are we tallking soldering, clamping etc.?
Old Nov 2, 2005 | 10:33 AM
captret's Avatar
The connectors C1 & C2 on the "Dietz" are the same as connected to your COMAND.
Each wire is "pinned" or clipped into the connector...you just "unclip" the wire from the Dietz connector and plug it into the same spot on the COMAND's connector.
I'll try to attach a photo of the C2 connector...a picture is worth a thousand words.
Old Nov 2, 2005 | 10:38 AM
captret's Avatar
Originally Posted by linuxfoo
hi captret,
I don't have a wiring diagram for the Dietz, as I said, I just swapped out the wires, they may have one on their website. I'll let you know about selling Steve's adapter.
Old Nov 2, 2005 | 06:59 PM
linuxfoo's Avatar
thanks captret for the photos.
Old Jul 31, 2019 | 10:03 AM
ctravis595's Avatar
2002 CL500 to CL55 conversion
Old thread, but I dont really care, should I make a new one when this has already been discussed with lots of good info here? I think not
this is the first im hearing that we can hack the 2003 command 2.0 US version into playing video. I’m very interested and will be researching the adapters mentioned today. However like most electronics threads from 2005 regarding these cars, the adapters often aren’t still available etc. so I was wondering if anybody has a modern day equivalent etc
