Unlock Comand - W211
Rating: Thread Rating: 2 votes, 4.50 average.
Old 10-05-2013, 05:35 PM
  #51
Mackhack's Avatar
Don't do anything if you don't know what you're doing! This is my best advise before you will end up here again asking how to fix your COMAND bc you bricked it!
Old 10-05-2013, 07:55 PM
  #52
OzFl's Avatar
2014 GL 350
Thanks. That is the exact reason i was asking. I dont want to mess anything up. I am looking for people with experience that can shed some light. Have you done anything yourself?
Old 10-05-2013, 09:04 PM
  #53
Mackhack's Avatar
Many times inside engineering menu, hardware wise as well as with my Star Diagnosis.
Check out my signature and my website for some clues
Old 12-08-2013, 01:01 PM
  #54
rommelle63's Avatar
04 e320 4matic wagon
In case this is still current...
The problem is that everyone tries the wrong order of the keys to enter the hidden menu.
Correct sequence: # then * then < NOT * then # then <
I have tried it in the sequence you mentioned above and still can get past welcome to engineering . any ideas
thanks
Old 12-08-2013, 01:04 PM
  #55
Mackhack's Avatar
Updated firmware doesn't allow it anymore. I can help you like I just told you in an email.
Old 09-28-2014, 10:25 PM
  #56
judge01's Avatar
2003/2004 E320 W211
Smile
thanks
In the engineering mode, press and hold the numbers "1 - 3 - 8" it will take you to the update part, then press back button to get back to engineering mode and press and hold "1 - 4 - 7" it will give you the options driver distraction and the dvd region settings, also enable the MP3 listening. The method with # * and < didnt worked for me. This with numbers worked on my euro E320 2003/2004.
Old 09-28-2014, 10:38 PM
  #57
Mackhack's Avatar
I will say it again even if I said it a 1000 times already. As soon as you have firmware 30/06 on it there is no DR.DIST menu anymore with the known codes. Harman/Becker changed them and kept them a well known secret for good reasons.
Also: DR.DIST would only be available in ECE spec COMAND NTG1, not US spec COMAND NTG1. Every other COMAND doesn't even have it implemented. If one wants to watch DVD or TV while driving need to put a CAN-Bus filter in to fool the COMAND (NTG2.5 and newer) into believing that the car is at a stand still. BUT: if that is the way to go, your Navigation will not work anymore as long as you watch DVD for the obvious reason.
Old 07-17-2015, 10:37 AM
  #58
ihlhunter's Avatar
Mercedes E320 CDI
Just unlocked my E320 Comand. Many thanks to Mackhack. Used the # - * - < worked no problem.
Ian
Old 07-17-2015, 01:02 PM
  #59
Mackhack's Avatar
Anytime.
Old 08-16-2020, 05:18 AM
  #60
George Oghlian's Avatar
03 E500
Ian
I see those Buttons (#),(*) But what about this (<) what’s that button, left arrow?
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
Quick Reply: Unlock Comand - W211
