Unlock Comand - W211
Old 08-04-2006, 04:52 PM
monial's Avatar
I am trying to unlock my W211 E320 EEC (Dec 2003) comand device.
I have done the following:
1) hold simultaneously Mute+hangphone+serv buttons and then I get to the Engineering menu
2) I hold simultaneously the * + # + < buttons in order to access the "secret" menu that gives access to functionalities such as "DVD region code free", playing DVD while the car is in motion and so on.
Unfortunatly the code I have doesn't work and I can't access the menu...
Any one to help ?
Old 08-05-2006, 01:09 AM
steve.link's Avatar
Have a look at this link
http://www.freenetpages.co.uk/hp/tow...DENMENUsv2.PDF
Old 10-24-2007, 03:57 PM
Tariq's Avatar
S500 W223 2021
I did the same and i'v look the the link that u sent, but still unable to get the engineering mode!!!
Old 10-24-2007, 06:22 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Any one to help ?
Or try the link in the first post at http://www.benzworld.org/forums/audi...ock-codes.html
Old 10-25-2007, 03:15 PM
Tariq's Avatar
S500 W223 2021
Skylaw, i'v red that thread , its just show how to enter the secret engineer mode, our problem is we are unable to cross the first step which entring the engineer mode which requier to be in audio menu click on must+Hung up phone + serv , therefore we hold pressing the keys for more than a menit but it cannot enter the engineer mode.
please advise what that because and what to do..
Old 10-25-2007, 03:30 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
Folks,
The E-Class (W211) NEVER came with a DVD drive except the euro version between 2003 and 2006
The US versions can only be manipulated to play mp3's and then only after 2004.
I huess the euro version is what we are talking about
here right?
Old 10-25-2007, 03:40 PM
weinschela's Avatar
'14 E350 wagon; BMW G12 (2020) G01 (2019)
Originally Posted by my06clk
Folks,
here right?
This is not entirely correct. My US 04 E320 and 05 E500 both had DVD drives. I do not believe that video was activated on these, but audio DVDs (burned with MP3s) worked just fine. I'm not sure when they switched over to CD drives in the US for the Comand, but I know my 08 E550 has no DVD and I believe this is so for the 07's also.
Old 10-25-2007, 06:19 PM
Tariq's Avatar
S500 W223 2021
Folks,
here right?
Well i have a Euro comand and i can play DVD but i want to play it in motion while driving, so i cannot enter the Engineer menu mode at all as i try to click mute , hung up phone and serv for many more than 50 seconds...!! but unable to get that engineer setting.
Old 10-25-2007, 08:39 PM
my06clk's Avatar
Hmm interesting..Most of these cars only came with CD drives. They could play Mp3 but only in cd format. Your Comand was a US version as well as the car?
In that case there must have been a few out there then I guess..... Thanks for the correction.
Old 10-25-2007, 11:14 PM
nye500's Avatar
06 e55 amg and 05 CL65 amg
I thought you were right also, but maybe there are a few out there!! I can't play dvd's on my 04 w211
Old 10-26-2007, 09:05 AM
weinschela's Avatar
Yes, these are US Comands with DVDs, and I believe that many 04s and 05s have them. To play MP3's the 04 required a software fix that my dealer did for me. The 05 played them from day 1. The 04 was delivered Feb 04 and the 05 was delivered August 04.
Old 10-26-2007, 05:10 PM
cocacola's Avatar
W211
04 W211 can play MP3
2004 W211 US Comand can play DVD MP3 by software update. The update can be done by dealer. Or, if you want to do it yourself, the software update disk can be purchased at dealer parts dept for about US$10. The Disk part number for 2004 US Comand is W211 589 07 22 00 (SW-Rel 10.270 Build 13/04).
Most important, you still can unlock your Comand with this software update!!!
Old 11-06-2007, 08:52 AM
anerbe's Avatar
C63S past: E90 M3 6M, w211 E55
will this disk work with european COMAND? I got the euro unit installed by Steve and it doesn't have the MP3 option in the engineering mode, just driver distraction.
also, for those who can't get into engineering mode for the 03's, i just started pushing buttons after loosing feeling in my fingers from # * <, and got into it.
Old 11-06-2007, 02:12 PM
cocacola's Avatar
W211
EU COMAND and US COMAND have different firmware and not interchangeable.
The latest software update for european COMAND part# W211 589 13 22 00 (SW-REL 21.090 30/06), but this will removed the Engineering Menu access after the update.
Old 11-07-2007, 08:59 AM
anerbe's Avatar
that sucks - any news on a previous software release from 2005?
also, if we install this, will our settings be lost as in DVD in motion? or will the menu options just disappear, but we keep functionality
Old 11-07-2007, 06:34 PM
cocacola's Avatar
W211
The older firmware for EU COMAND Part# W211 589 06 22 00 (SW-Rel 9.390 Build 17/04). I believe this is the last one one that still has the Engineering Menu back door enable. I might be wrong.
Even if you upgrade to the latest firmware with Engineering Menu back door remove, someone who have access to modified/hacked SDS still able to enable/disable MP3, DVD in motion, etc. Basically, no more accessible from the keypad anymore after the upgrade.
Old 11-08-2007, 11:06 AM
anerbe's Avatar
thanks for the information cocacola!
last question (I promise) - did the 17/04 SW have MP3 capability? I assume not.
Old 11-08-2007, 01:36 PM
cocacola's Avatar
W211
Old 11-08-2007, 08:23 PM
anerbe's Avatar
interesting *leaving self note to order from dealer tomorrow*
haha thanks!
Old 11-08-2007, 09:11 PM
cocacola's Avatar
W211
Please keep this in mind before upgrade
Please also make a note that if someone trying to downgrade their COMAND from higher version of firmware to lower version(or that someone think that he/she is smarter than Mercedes for re-enable the Engineering Menu by downgrade the firmware) , that someone may find that the COMAND may become a brick after the downgrade firmware. And the COMAND will not accept any update disc at all after that.
Thus, always check to see if the current firmware on the COMAND are older or the same version of the firmware that someone planning to upgrade.
So, you have been warned!
Old 11-10-2007, 12:37 PM
anerbe's Avatar
EU W211 589 10 22 00 26 Jan 2006 SW-Rel 15.130 Build 51/05
any news on this update. It looks like it's between the 9.39(04) and 21.09(06) . Curious if this loses engineering mode functionality
Old 11-10-2007, 08:11 PM
evdok's Avatar
CHIPPED E320 CDI
if you guys were in the uk i would unlock them for you, i have the tools & prog.
Old 11-16-2007, 01:31 PM
anerbe's Avatar
i'm looking to get both the W211 589 06 22 00 COMAND and W220 589 04 22 00 update disk.
The dealer can special order the W220 589 04 22 00 disk, but says the W211 589 06 22 00 is not available. Anybody have the disks available? I can pay for the disks and shipping, or just pay for shipping from and to.
Old 11-19-2007, 06:50 PM
evdok's Avatar
CHIPPED E320 CDI
i use this prog & this tool
Old 11-19-2007, 09:39 PM
paullee129127's Avatar
w221
Talking
Any one to help ?
Hello
who do know "Seatbelt acoustics deactivation for W221,W211,W164 and so on".and anybody has this software or tools? pls send e-mail to me as below paullee129127@hotmail.com
Regards
Paul
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
Quick Reply: Unlock Comand - W211
