Sponsored by: Innova
SL55 - external AV
Rating: Thread Rating: 2 votes, 5.00 average.
Old Jan 31, 2003 | 04:35 AM
  #101
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
Originally posted by cone
Richard, I am agree. I can produce for you. Is it possible with options, Able & disable tv interlocks and to program tv switch for comand without tv tuner?
Hi, yes this is the intention, and Im already working with an associate in the US to produce this using a m icrocontroller and some other bits that they already use.
We'll make it so it can switch on/off the TV flag (so that the TV button springs into life on US units, and you can then plug in a megacomm interface) and so that it can switch on/off each of the 4 TV interlocks
(2kmh, 10kmh, foot-brake, P gear)
It will take a few weeks (especially as Im on holiday for a week in a couple of weeks time), so please hang in there
Cheers,
R
Old Jan 31, 2003 | 04:43 AM
  #102
cone's Avatar
2013 SL 350, ML 350 BT
Cheers,
R
Richad, you are in the right way. I´m sure will be a succes. All MB enthusiasts we will grateful for your job.
Old Jan 31, 2003 | 05:48 AM
  #103
London Lad's Avatar
SL55
Mustard,
Yes they sorted the rattle, a long story but it turned out to be the rear left hand brake cable adjuster locknut not done up tight!
It is near the exhaust and as it heated up the rattle disappeared.
But I have loads more trouble now! See :
https://mbworld.org/forums/showthrea...489#post264489
Car went in again yesterday and they reset all the faults stored in memory but can't find the problem. I’ll give it a few days for some to re occur and then I'll have to start making a fuss!
Graham.
Old Jan 31, 2003 | 08:22 AM
  #104
Mustard's Avatar
BMW 535d Touring
Frustrating. Hope it gets sorted, at least electrical faults don't rattle! - missed the earlier thread....
Old Feb 9, 2003 | 02:25 PM
  #105
cone's Avatar
Cheers,
R
Hi Richard, how is your work on your device? How long must we wait until you finaliced it?
Old Feb 9, 2003 | 06:09 PM
  #106
Richard's Avatar
Were a few weeks away Im afraid .. rather busy with real work !
R
Old Feb 19, 2003 | 12:25 PM
  #107
cone's Avatar
R
Richard, next april, I will have my new SL 350 with comand and tv tuner,I would like to know where are tv antennas? What kind of tv tuner has this model and where is located? Is it possible to disable "tv tuner off" while is moving on the SL?
Old Feb 19, 2003 | 12:29 PM
  #108
London Lad's Avatar
SL55
Cone,
TV ants are in the front screen
graham..
Old Feb 26, 2003 | 05:41 PM
  #109
cone's Avatar
Cheers,
R
Richard, when will we have news from you?
Old Mar 2, 2003 | 03:01 PM
  #110
cone's Avatar
New AV source
I hope you will like this new av source http://www.cinemadisk.co.uk
Old Mar 2, 2003 | 03:50 PM
  #111
Richard's Avatar
Now Im back from holiday and the weather is improved in the US (where my colleague is), we are making some progress - the code is just being done on a prototype platform, then we'll make a board, probably with a single switch that does
(a) TV enabled, all interlocks disabled
(b) TV enabled, speed interlock enabled
I'll let everyone know when there is more progress
Cheers
R
Old Mar 3, 2003 | 10:46 AM
  #112
scipion's Avatar
I read the all thread, and it seems very interesting as I am a unix dev too.
Richard, can you prog do anything else disabling/enabling the video ?
remove limiter or trick hack the command ?
scipion
Old Mar 14, 2003 | 05:07 PM
  #113
cone's Avatar
R
Richard, I´m still interested on it , but I have just send my comand unit to Megacomm in Germany for disable interlocks because my wife doesn´t want to travel without watch tv on front monitor. Next week I expect to have my unit ready for use . Can you tell me what configuration will I see in my comand after disable tv interlocks? How is your work on your device for remove interlocks?
Regards
Old Mar 26, 2003 | 04:58 PM
  #114
cone's Avatar
Cheers
R
Hi Richard, how is your project, when will you have it ready?
Cheers
Old Mar 26, 2003 | 05:40 PM
  #115
Londonboy's Avatar
Interlocks
Cone
My TV was fitted by Megacomm, and at the time I never asked for all the 4 interlocks to be switched out/off, this was because I didn't know it could be done.
Megacomm's default setting was to switch out two of the four interlocks, the Park and Footbrake locks were off...
On returning to the UK I got the other two interlocks switched off/out as well..
So if you have asked Megacomm to switch off all the interlocks, you should definately get two off, and maybe all four..
Let me know how you get on and how much you get charged
Good luck
Steve
Old Mar 27, 2003 | 04:05 AM
  #116
cone's Avatar
Re: Interlocks
Originally posted by Londonboy
Cone
Good luck
Hi, they did it in my 2003 S Comand two weeks ago, it cost 149 euros plus shipping, now, I receive my new SL 350 with comand and tv but I don´t want to disassemble from my car, that is why I ask Richard when will be ready his "device", another question is, when my dealer uses the Strar diagnosis in my car, I need to remove Comand´s fuse for not activate tv interlocks again.
Old Mar 27, 2003 | 04:42 AM
  #117
Londonboy's Avatar
Fuse removal
Hi Cone
I think I understand your question..
I have never removed my fuse from Comand before taking my MB in for a service. I have had one A service and two oil change services from an MB agent/dealer, and the TV still stays on..
Hope this helps
Steve
Old Mar 27, 2003 | 04:43 AM
  #118
Richard's Avatar
Re: Re: Interlocks
Hello,
We are beginning to make some progress on the device, Im still not committing to a date though.
- If the dealer specifically changes any setting on COMAND using Star diagnosis, the speed > 2kmh interlock will be re-enabled.
If the dealer is just reading the fault logs this will not be a problem, or if the dealer is changing other settings on other control units on the car - again no problem
Cheers
R
Old Apr 5, 2003 | 04:39 AM
  #119
cone's Avatar
Re: Re: Re: Interlocks
Hello,
Cheers
R
Hi Richard, I have my new SL350, can you tell me where is the TV tuner located and how to accede it?
Regards
Old Apr 17, 2003 | 08:18 AM
  #120
Tempman's Avatar
W210 e55 1999
Im near heathrow - bit to busy to make it to spain sadly :-)
However, Im thinking seriously about getting someone that I know to build a plug in box that you just plug into the diag socket and it reprograms the COMAND interlocks.
Will probably work out at somewhere between $200 because the volume wouldnt be high - but you can then sell the service to whoever :-) Is that too expensive to make it worth while ???
Cheers
R
Richard
I would be happy to pay you $200 for your device! Please let me know when its available
Old Apr 17, 2003 | 03:18 PM
  #121
Richard's Avatar
Originally posted by Tempman
Richard
Just an update for you, we have the first (test) version of the software - which I will put thru its paces this weekend - we are working between 2 continents, so things can go slower than we would like.
R
Old Apr 23, 2003 | 04:33 PM
  #122
merlin's Avatar
E55
Richard,
I followed the whole discussion with high interest. I've got the hardware (interface from Andrew) and the software compiled on a linux system. Question to you is now if you can tell me how to proceed in order to get rid of the blocks.
Or do you prefer to wait until you have your "out-of-box" device ready ?
Obviously I would like to have a solutions as quick as possible but I fully understand if you prefer to go only for the solution you are currently working on.
In any case I would like to tell you that I highly appreciate your contribution.
regards
merlin
Old May 15, 2003 | 12:01 PM
  #123
cone's Avatar
R
Hi Richard, how is your project? I saw , there is a new Brabus internet comand kit, can you tell about it? Please, visit this page
http://www.jes-mercedes.de/indexie.htm
Regards
Old May 26, 2003 | 05:14 PM
  #124
Shandy's Avatar
Mercedes C43 AMG
Richard, I have been following your work with more than interest, I live not far from you, I have a 2002 SL55 AMG and desperately want my interlocks removed, and I would definately be interested in paying you $200 immediately!
I hope your development is going well, if there is any help you may need I will be more than happy to help.
I have an S500 which I was lucky enuff to bully Merc dealer in Lakeside to remove all interlocks (in November) as I said my reverse camera wouldn't function with the locks on and made a song and dance about it..they luckily removed them for me but I don't think I can ask them any more favours if you know what I mean...
be happy to pay for your talents....
Old May 31, 2003 | 12:12 PM
  #125
cone's Avatar
Me, too. When will you have news, Richard?
Rigards
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
