Sponsored by: Innova
A customization Question
Old Aug 2, 2007 | 09:12 AM
romz's Avatar
2001 C240
Hello Everyone I am wanted to get some opinions. I wanted to get a system installed in my 01 c240 and was thinking to take out what ever is connected to the SOS button and connect the power to the subs. What do you guys think about it and how much it would cost to do something like that. Any opinions and suggestions would help. Thanks in advance.
Old Aug 2, 2007 | 12:41 PM
Diesel Benz's Avatar
Does not sound like a good idea (even if I had difficulties figuring out what the idea actually was).
Old Aug 2, 2007 | 01:06 PM
romz's Avatar
2001 C240
So it would not be recommended?
Old Aug 2, 2007 | 01:33 PM
ldangeli's Avatar
EFF YOU JACKIE
What exactly are your trying to do? Run amps and a sub?
Old Aug 2, 2007 | 01:34 PM
ajent420's Avatar
2002 E320 4MATIC
I wired my SOS button to eject me through the sun roof in case of emergency. Easier to do than you think!
Old Aug 2, 2007 | 02:17 PM
romz's Avatar
2001 C240
Yes I am trying to put a complete new system in the car and the spot over head where the lights and the sunroof buttons are there is an SOS button and my subscription expired so it does nothing. My parents often use my car and they don't like the thumping of the subs in the back so I figured since that button does nothing any more to put a kill button for the subs there instead of making another one and locating on the car. Would this be a simple task or would it be to expensive and not worth it?
Old Aug 4, 2007 | 07:32 PM
narf's Avatar
W211 E55 AMG
i dont know how the wiring is in the car, so i cannot say with any certainty; however, i believe just wiring a simple switch to kill the power to your amps from the front seat somewhere would be much easier, and you even hide it (under the steering column or wherever) to make it discrete.
Old Aug 5, 2007 | 05:03 AM
rob13572468's Avatar
PREMIUM SPONSOR
ML350, Lotus Elise
yes it can be done but the biggest issue is that the SOS button is not the right type to allow direct connection... the existing button is momentary (it onloy connects as long as you are pressing it) so you will need a device called a racheting relay which will convert the button press to a on/off state. then it is simply a matter of cutting the existing wires from the button and rewiring them to the relay...
Old Aug 6, 2007 | 03:30 PM
romz's Avatar
2001 C240
thanks for the info guys I will keep it in mind when speaking to the audio store for the installation.
