Got my system in!
1, 12" kicker SOLO X. 2,000 watts to just the one sub. very loud if wanted, very crips and clear base. ported box. the car sounds great no rattles! You have to love a benz
here are the specs from online
Model : S12X1
Size (IN., CM) : 12, 30.5
Impedance (OHMS) : 1 DVC
Max Rec Amplifier Power (WATTS PEAK) : 5000
Max Rec Amplifier Power (WATTS RMS) : 2500
Sensitivity (dB 1W/1M) : 87.7
Frequency Response (HZ) : 20-100
Mounting Depth (IN., CM) : 8-9/16, 21.7
Mounting Cutout, Square (IN., CM) : 11-1/4, 28.6
Recommended Box Volumes: The SoloX is engineered for highly specialized installations/applications.
sorry for the bad amp pics... the box sits on the cover for the spare so i can only lift a few inches.
I have done all my stereos with Transportation electronics since day one. he has never let me down. most of my systems have been much more elaborate
I was messing with you relax, The beater with a heater is a joke also, and don't even get me going on what sounds good, because I can't hear your system in person However, if you consider loud output as sounds good, then we will disagree, properly matched with the rest of the audio system, then we are fine, but i doubt the latter because of no mention of replacing the front speakers and properly amplifying them, so that it can actually produce a decent midbass presence...
I do believe the installs low budget though for being a Mercedes, and that is not saying anything wrong with you or your decisions, just the installers or shops. Some people don't know what to look for. For instance the amp placement, crappy wiring, the budget woofer box that looks like they used particle board, the port opening is horrendous, lack of any grill (not that it is a huge issue, but the first time you have to place something in the trunk and dings the woofer you will be ticked) (also i have done the same thing like 10 years ago, stating i will never put anything in the trunk... which i ended up doing) also what about access to the spare? Now we all know you get what you pay for, and I am not taking pot shots at you... but I believe that the low quality of installs and installers out there just sucks.
