Need instructions on GPS charger hardwire DIY
Is it possible?
I'll cut the wire off and take a picture if somebody is willing to give me some instructions. Please make the instruction easy to read for a electronic noob. I dont have much experience on this field as I'v only done hardwiring a V1 with the kit included with the package, and thats all.
Some notes i think worth mentioning:
There's a tag which says "Input:12V/24V Output: 5V/900mA Made in China"
and, the plug (the plug which goes into GPS unit) is exactly like a Motorolla cellphone charger plug (the plug which goes into Cellphone).
Here's a picture of the charger:
Is it possible?
Dont cut the charger and try to wire it directly or you will damage your GPS. You need to get a direct wire receptacle (a cig jack on one end and open power wires on the other. and wire that to power instaed and then hide the whole thing under the dash somewhere.
Does it mean that i just splice another cig. lighter with the wires behind the original cig. lighter?
The pinout for USB is
1 VCC Red +5 VDC
2 D- White Data -
3 D+ Green Data +
4 GND Black Ground
I can think of a number of ways to step 12vdc down to 5, but if this is your first project, I'd just go to Radio Shack and pick up a "cigarette lighter socket", and wire that in behind the dash, and plug your adapter into that...
But ya, i think i'll just do what u guys suggested.
Thanks a lot
