Sponsored by: Innova
Auxilliary wire for comand
Old Nov 30, 2002 | 07:02 PM
oggle's Avatar
E320
Just got my European Comand installed. However the auxilliary output is bare naked. I'd like to get the auxilliary wire and hook it up into the glove box. Does anyone know anything about this?
Old Dec 3, 2002 | 03:49 AM
Class C's Avatar
W203
Let me find out the part # for you, I'm sure it's just a plug and play thing....
I want one too...
Old Dec 4, 2002 | 03:11 PM
E320's Avatar
you just need to add 4 wires to the C2 connectors.or you can get the C2 wiring harness from the dealer.
Old Dec 4, 2002 | 03:17 PM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
Can U post the part number (or PM me), i'll add it to my document.
BTW, Im not sure what you mean by the "output is bare naked", the wires connect to C2. In fact, on a CLK (W208), they connect to a 4 way connector, which is then connected to the aux input in the glovebox.
Probably easy to just buy a 3.5mm socket and connect up the cables yourself
Cheers
Richard
Old Dec 4, 2002 | 05:50 PM
E320's Avatar
Richard,
I don't know the part # for the wiring harness but i know the part # for the contact pins ,I just used regular wire.There's a correction on your documentary the speed sensor should be put on C2 #6 not #15.
Old Dec 8, 2002 | 03:39 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
It is said to be: 210 440 50 05
greetingz,
Old Dec 10, 2002 | 02:01 PM
Richard's Avatar
Thanks for both those pieces of info. I'll put an updated document up shortly. (www.ibex.co.uk/mbstuff)
Old Dec 10, 2002 | 04:54 PM
oggle's Avatar
E320
Great info... but what pins do I connect them to?
Old Dec 10, 2002 | 05:30 PM
Richard's Avatar
I updated my document , pins are described there (just added the aux input pin id's)
R
Old Dec 10, 2002 | 06:32 PM
oggle's Avatar
E320
R
Thanks Richard! Question about that though... Since there are no pictures on your site, could you tell me how the pins are numbered in the picture?
Old Dec 11, 2002 | 03:58 AM
Richard's Avatar
The connector has numbering on it .. I;ll try dig out one and look
R
