Sponsored by: Innova
www.kabeldaviko.de
Old Mar 9, 2009 | 01:46 PM
DeutscheM's Avatar
E500 w211
www.kabeldaviko.de
Hey all
anyone has installation instructions for : http://www.kabeldaviko.de/w211-219.html
I really appreciate it!
BR
Old Mar 9, 2009 | 04:11 PM
Diesel Benz's Avatar
Originally Posted by DeutscheM
Hey all
BR
Are you from Germany? If you were from the US, you should not need this harness.
But if you have an Audio 20 CD head unit, this seems to be the necessary set.
But if you do have an Audio 20 CD, shouldn't you consider this other option and an NTG2.5 Comand:
http://www.kabeldaviko.de/w211-219_comm-2-5.html
The installation instructions should not be much more than finding the way to route the cable from the front to the trunk.
Old Mar 9, 2009 | 07:41 PM
DeutscheM's Avatar
E500 w211
nope i am not from Germany but close enough
What i have is a US spec E500 with Audio50...i need to install aftertmarket HU and i am having a headache trying to figure out all the wires and the radio antenna and how to power it
any insight?
Old Mar 10, 2009 | 03:55 AM
If you have a US Audio 50, you should have the AGW at the trunk, including the FM/AM tuner and the amplifier.
It is not straightforward to install any after market unit in this case. You would have to find a way to power the antenna amplifier and you would need to wired speakers from the front to the rear (where some would come back) and you would lose all devices on the fibre ring.
Old Mar 16, 2009 | 06:25 AM
DeutscheM's Avatar
E500 w211
thanks for the reply
I dont care about all the devices at the fiberring!! the CDC, HU, Teleaid and phone devices are all going OUT
i am also aware of all the wires i need to run to the front and back
BUT
can you please help me out in figuring out a way to power the antenna amplifier?
i would REALLY appreciate it
BR
Old Mar 16, 2009 | 10:33 AM
UK-C200's Avatar
RHD C200 Sport Coupe, RHD SLK-55, LHD SLK-350
Trivial, but you still have to run the wire. Block B, pin 7 on the NGT2.5 harness.
Old Mar 16, 2009 | 08:42 PM
DeutscheM's Avatar
E500 w211
thanks UK-C200....do you know that pin correspondes to which pin in the AWG?
Old Mar 23, 2009 | 08:50 AM
DeutscheM's Avatar
E500 w211
bump
Old Mar 23, 2009 | 03:48 PM
Connector 5a, pin 1, yellow wire.
