W211 - Speaker only upgrade on Harmon Kardon system
Old 11-09-2009, 11:23 PM
pinebaron's Avatar
07 E320 Bluetec
Originally Posted by emilner
I was looking to replace the center speaker to improve the soundstage on my 212. It is a 3.5" DUAL voice coil! Ugh. I cannot find anyone who makes one. Right now the soundstage is terrible, female vocals come from the drivers side mirror. I wanted a higher sensitivity two way 3.5 to increase the output, now I am stuck. Any suggestions?
The only way is to add an amplifier; see my thread, though it only addresses four door speakers/tweeters. Similar amplification may be achieved for front center speaker only after center speaker is replaced to match the amplifier or desired output. Anything is possible. Are you planning to DIY?
Old 11-10-2009, 02:31 AM
laxatdu's Avatar
2003XPFord
Great info! Really informative. It is helpful for me.
Old 11-10-2009, 09:51 PM
emilner's Avatar
S560
I would definitely DIY it. I did not want to go crazy with the system. I was hoping for an easy speaker swap. I am surprised that the stock components did so well for you, that is not usual- normally that is the first upgrade. I would not just re-amp the center- now you are talking about your upgrade along with the center. I am just surprised MB cheaped out with a dual voicecoil L/R center instead of a dedicated center channel!
Old 11-11-2009, 05:41 AM
jbondox's Avatar
beater with a heater
Look, this guy doesn't know what he is talking about. the 212 as you have is way much more easier to add an amp to as your command has Hi-level 4 channel out on the back that can be enabled by an MB dealer, or quite possibly it is even enabled now, as I have seen a few like that. your center channel is like that because, it is the sos voice from the telaid system. just add an under dash speaker. use the blu/brn and blu/vlt speaker wire colors
further on the 211 that this guy is butchering up, the aftermarket speakers would make a huge difference if properly installed. obviously they were not properly installed! also I mentioned to remove the mic, but obviously he knows so much... anyways i just needed to put a stop to his train wreck of a post with all the BS...
Old 11-12-2009, 07:32 PM
pinebaron's Avatar
07 E320 Bluetec
Let me know if you need more information. Don't disconnect the mic, or butcher the system with under dash speakers etc. Last night I had a car load of people and they loved the distortion free sound clarity even at 110dbs overall at center armrest (very bad for your ears at that level). I have not had time to run the spectrum analyzer but will publish results when I do.
Old 11-13-2009, 04:39 AM
jbondox's Avatar
butcher? that would be your installation or lack of, the only thing missing is the bloody coat hanger.
Metering it is going to do what for you?
Go ahead and introduce pink noise into the system, then analyze it. which will confirm that you don't know what you are talking about. go ahead and try it then adjust the volume as you can see what the mic does to your system. and there is no need to BS us either as I already done it years ago... and know the answer... I use the sa3055 audio control RTA and a calibrated mic.
as for the 212 E class, you will have to add an emergency speaker, as that is what the second set of coils on the speaker is for... explain to me what you would do for that? especially when trying to get the most out of the center channel? something bullet proof that will work with no power applied to it?
Emilner, your vehicle is completely different than his, audio system included. yours is capable of 7.1 DSP sound, not a true 7.1 as home, but similiar in way the DSP works.
there are many ways to approach a project that is an upgrade just do it correctly. you don't have the DSO, or sound optimization microphone so it will not need to be bypassed. If you do not have the hi-line system with the powered sub, your center channel is derived from the Left positive and right negative signals of the door speakers.
Old 11-13-2009, 04:54 AM
  #32
jbondox's Avatar
Old 11-14-2009, 05:20 PM
  #33
pinebaron's Avatar
07 E320 Bluetec
Despite jbondox being hubristic, I find him very amusing.
Old 11-14-2009, 05:56 PM
  #34
jbondox's Avatar
LOL.... Yeah I was just playing around... it was like 3AM, I was finishing up some paper work... I blame it on the Red Bull's
Old 11-15-2009, 10:24 AM
  #35
jbondox's Avatar
my next photo was going to be the studio...
emilner, for a center speaker that fits with no problems, check out the Hertz HL70.4, it has to be the .4 model though as it is the new version. i just used it in a 5.1 system with a separate tweeter, and I can only say phenomenal!
Old 11-15-2009, 10:26 AM
  #36
jbondox's Avatar
what better way to reference music :whistle:
Old 11-15-2009, 10:06 PM
  #37
emilner's Avatar
S560
The only problem is it needs to be a dual voice coil. H/k cheaped out and wired a dual voice coil speaker instead of setting up a dedicated center channel....
Old 11-16-2009, 02:07 AM
  #38
jbondox's Avatar
Read a few posts before, it is dual voice coil because that is where the SOS system talks out of in an emergency...
Old 11-16-2009, 10:12 AM
  #39
emilner's Avatar
S560
Sorry, missed that post. The wires you mentioned are for the emergency speaker right? You mentioned I might have a hi-line system w/ powered sub, how do you tell which system I have?
This sounds like good news. Now if I could get rid of the rattles in the car and thumping in the trunk...
Old 11-16-2009, 02:12 PM
  #40
jbondox's Avatar
if you have the sub in the trunk, rear deck, you have the hiline
Old 11-16-2009, 07:54 PM
  #41
emilner's Avatar
S560
There is the oddest looking sub I've seen in the rear deck. It looks like a 10-11" X 6-8". Its tough to see the actual dimensions b/c you can't see the whole speaker (definitely bigger than a 6X9). It also has dual VC's and they are inverted (where the cone would normally be). Strange speaker...
Old 11-16-2009, 08:15 PM
  #42
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
I've numerous subs where the magnet structure is inside of the cone due to space constraints. It allows for placement where a conventional sub would interfere or take up space and receive possible damage from objects shifting in the open space/trunk.
Old 11-17-2009, 10:02 AM
  #43
jbondox's Avatar
manufacturers do not want to put a space eating enclosure in the vehicle. so companies as HK, Bose, Mark Levinson, etc come up with funky designs... but at the same time it has to be cheap and affordable both to the manufacturer and the end user.
Old 11-17-2009, 07:17 PM
  #44
Administrator
amdeutsch's Avatar
MPG+ ROLFCOPTER
By whose definition?
Old 11-18-2009, 11:10 AM
  #45
jbondox's Avatar
lets see.... how about the people I know at Rockford Fosgate and HK OEM side to start
Old 11-18-2009, 09:18 PM
  #46
emilner's Avatar
S560
Ladies put it away!!!!
Old 12-20-2009, 11:53 PM
  #47
zayasw's Avatar
E350
My friend: nice job you certainly did there. I have been strugling in the connection to upgrade mine, but now thanks to your guide I will be able to do it. The Star Tek website had everything I needed in terms of wiring diagrams. Just a couple of questions:
- Have you had any electrical problems thereafter with the car? The owners manual says that nothing is to be connected directly to the battery since it may damage the module controlling the two-battery module system.
- What could go wrong if I get a 4 ohm amp and connect it to the factory speakers as you did?
- If I get to change speakers, may I put three-way's instead of the component speakers?
- If I get a sub, should it be a free-air? or should I get an enclosed sub (like a bazooka or something) and put it in the trunk to have a nice thump?
Thanks!
Originally Posted by pinebaron
http://www.systembiz.com/W211Speaker...lifierinstall/
To take additional pictures I had to remove the side panel etc. and while I was at it, I increased the amplifier gain even more and OEM door speakers handled the extra power easily; it needs to be clean audio power. I have not had time to verify # of audio watts actually reaching each door speaker through Rockford Fosgate 600-4 amplifier, but experience tells me it is well in excess of 100W RMS per door, which is now extremely bad for your ears.
Even though OEM door tweeters are adequately handling additional audio power, I feel a need to turn them down a few DBs at higher volumes; I will soon publish comparitive output graphs . Since this thread is not about just replacing everything, not messing with or bypassing HK equalization and not installing additional audio equalizers, I will add an attentuator (easily done) to control tweeter output. Aftermarket speaker component systems usually come with adjustable crossovers that have slope and attentuation switches.
Old 12-21-2009, 09:11 AM
  #48
pinebaron's Avatar
07 E320 Bluetec
Thanks!
- Absolutely no electrical problems whatsoever
- The amp I installed is 2ohm/4ohm compatible. OEM speakers are 2ohm hence I selected a compatible amp since I went back to OEM speakers. I intend to replace OEM speakers with component speakers in the new year. Your amp needs to be compatible with installed speakers. You could use 4ohm compatible amp if you intend to replace OEM speakers with 4ohm ones.
- 3-way speakers will work fine but I have no experience with 3-way 6.5" round speakers.
- An enclosed sub would be the easiest option to install and it will give you a nice thump.
Old 12-21-2009, 03:47 PM
  #49
beafer's Avatar
I dont know if i mentioned this before but the HK system that comes with the benz is really nice. The speakers themselves that is. With a little more amplification and good crossover points, they are even better. You would be very surprise of how good they sound when you send them about 50-75 rms to them.
Old 12-21-2009, 08:29 PM
  #50
pinebaron's Avatar
07 E320 Bluetec
I agree. OEM speakers with HK system seem to survive 100+rms and still produce clean sound.
Quick Reply: W211 - Speaker only upgrade on Harmon Kardon system
