Sponsored by: Innova
W209 Comand Retrofit: Where Does the GPS Antenna Go???
Old Jun 8, 2010 | 09:05 PM
vinsuz's Avatar
2007 CLK 550
I have an '07 CLK (W209) Cabriolet. Replacing the Audio 20 with a Comand but not sure where to put the antenna. Anyone know where it is on a factory install?
Old Jun 8, 2010 | 10:15 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
Factory spot is in the trunk lid.. but you dont have to run it there. Every time ive upgraded
the clk/c class to command i use a after market navi antenna and hid it under the dash ( above the ic) is a good place or you can put it in the rain sensor location under the glass..
Old Jun 9, 2010 | 06:55 PM
vinsuz's Avatar
2007 CLK 550
Thanks. I know the Sirius antenna is in the trunk, but I didn't realize the GPS antenna is installed there too. I found a good write up on www.mercupgrades.com that showed the antenna placement in a C-Class above the IC like you suggest, but I was hoping for another solution since I don't have to remove the air vents in order to install the headend like you do in a C-Class (I figure the less I have to dismantle the better).
Old Jun 11, 2010 | 02:52 PM
waveterrorist's Avatar
Firemist O5 CLK55 Cab Silver 05 CLK55 Coupe Tanzanite 06 CLK500 Coupe
behind cd changer
i picked up one for $15 on ebay.uk
small magnetic dude which fits perfectly behind the left rear portion of the cd changer.
working perfectly
Old Jun 11, 2010 | 04:11 PM
vinsuz's Avatar
2007 CLK 550
I found another post that says the antenna is placed in the dash above the instrument cluster when dealer retrofits a Comand in a W209. I ordered the special pulling hooks (part #W140 589 0233 00) to remove the ic.
Old Jun 16, 2010 | 03:56 PM
knock yourself out
pulling out your instrument panel
to each his own.........
Old Jun 17, 2010 | 06:45 AM
Diesel Benz's Avatar
Who was pulling out the instrument panel?
Old Jun 17, 2010 | 06:51 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
It's not that hard to get the cluster out
Old Jun 17, 2010 | 10:41 AM
Referring to your screen-name, no need for dynamite.
