Sponsored by: Innova
>>Backup Camera wiring HAZARDS ? <<
Old Jul 13, 2010 | 12:39 PM
michel sayegh's Avatar
Benz c230 kompressor 1.8l 198 hp
Hello I have just purchased this back-up camera kit for my 2003 c230 kompressor coupe , in the manual they advise to connect the power supply to the rear headlight so when the back up light turns on the camera would switch on automaticly , but i know that my car has electronics chips ... so i wanted to know is it safe to adopt this method SAFELY ?
Old Jul 17, 2010 | 11:20 AM
rob13572468's Avatar
PREMIUM SPONSOR
ML350, Lotus Elise
The likelyhood of it damaging the vehicle is low but still there is no real reason to wire the power at the lights.. The biggest issue is that the unit will typically not function properly because the rear light outputs are actually modulated (the output is a fast square wave...)
It is ok to connect the reverse sense input to the reverse light since that is just a signal. The power should be connected to a proper feed: the cigarette plug or power port is ok for that...
