navigation cds question
i recently installed the navigation from steve ,and now looking for the cd roms to get it to work does anyone know which cds i have to get? is there a difference between the ml , s class and other cds? i wanted to purchase from ebay but want to make sure it will work on my nav system first any help will be appreciated .....thanks ...........if any one has available pls pm me homemade or oem is fine thanx again
MB G500
The Nav CD's for the ML are DVD based I believe, so they won't work in a standard COMAND system. You need to look for the S-class type NavTech COMAND CD's.
1999 ML430
If you have the comand system you need dx based cds. They are made by navtech and I think a few others out there. If you have the MCS system you can order direct from them. Go to navtech.com.
1999 ML430
Depends on the system you have. If yours is dvd based then you only need one disk. If it is cd based then you will need several if you are traveling in the US. Mercedes has 3 types that I know of. The Comand, which is only cd based as of now and the MCS which comes in 2 versions, cd and dvd. I do not think the MCS works outside North America. I believe the dvd was new for 2003.
1986 560SEL, 97 BMW 740iL
Probably your Mercedes dealer parts dept. They could order one for you if they don't have it in stock. Or you could call MBUSA to order one.
